Audio question on a 91 C4
Old Mar 6, 2010 | 09:00 PM
jericko's Avatar
jericko
Default Audio question on a 91 C4
Hello
I just purchased my Dad's 91 Vette from him and besides needing new tires, I have a audio problem. It has the Bose system with tape deck. I was planning on replacing the headunit soon, but until then I was going to use my IPOD and tape adapter. Problem is when playing the radio or anything through the tape deck, it has a really loud hissing noise. I know nothing about car audio, but I was wondering is this hissing noise is a sign the amp is bad? Anything I can do myself?
Thanks for the advice!
Jason
Old Mar 6, 2010 | 10:30 PM
Disarray_kid's Avatar
Disarray_kid
Originally Posted by jericko
Hello
Jason
Ill take a shot at this. I want you to try playing with the volume. Let me know if this hissing soung get louder as the volume goes up and when it goes down.
Old Mar 7, 2010 | 12:03 AM
jericko's Avatar
jericko
It does get louder when you turn the volume up.
Old Mar 7, 2010 | 05:11 PM
Disarray_kid
ok now play with the fade and blance. go through all the speaker and see if they all do it.
Old Mar 7, 2010 | 07:18 PM
jericko's Avatar
jericko
Hello Disarray Kid, I did try playing with the fade and balance, and not luck.
Old Mar 7, 2010 | 07:52 PM
surfer92's Avatar
surfer92
If the radio is clear, probably means the heads are dirty on the tape deck or the CDM is bad.
CDM gets 1 signal from radio and another from the tape deck, clean the tape heads, I am betting on dirty heads. If that doesn't work, the CDM is bad.
Old Mar 7, 2010 | 08:01 PM
jericko's Avatar
jericko
Hello Surfer
It makes the hissing sound on both the tape player and the radio.
Old Mar 8, 2010 | 09:00 AM
Disarray_kid
Hello Surfer
Ok now the fun part. Take the covers off your speakers. Get a ol;d or new speaker head and put it in the place of one of the speaker outlet. And the fade and blance till only that speaker is on. If it still hissing then it the amps and you are looking at around $300 - $150 to replace all amps.
Old Mar 8, 2010 | 09:01 AM
vetteman42's Avatar
vetteman42
Active Streak: 90 Days
Hello
Jason
Contact: http://www.doctordons.com/
Many of forum member have used him including myself!
SAVE THE WAVE
Old Mar 8, 2010 | 09:03 AM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
You most likely have blown amps, could be the CDM (maybe) could be the head unit. The most common problem causing hissing is blown amps though.
Old Mar 9, 2010 | 11:35 AM
jericko's Avatar
jericko
Thanks to everyone who replied! I appreciate the input.
-Jason
To Audio question on a 91 C4
