How can this be?........Help
Old Mar 9, 2010 | 08:23 AM
jims1990vette's Avatar
jims1990vette
Default How can this be?........Help
Last year I put my car away knowing that it wouldn't start in the spring. I had it to my mechanic and he couldn't figure out what the problem was. The fuel pump had no power, the engine would just crank over but if you would spray starter fluid the car would start and then the fuel pump would show power. Although it would start for the remainder of that day, but the next day it was the same situation.I'm sorry if I have the terminology wrong I'm not a mechanic.I want to get her on the road and I know this forum has a lot of educated corvette owners so if I can get ideas i can pass them off to my mechanic.
Old Mar 9, 2010 | 09:02 AM
Calderone's Avatar
Calderone
After the spray,how long the fuel pump showed power ?
My bet is a bad fuel pump
Old Mar 9, 2010 | 09:05 AM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
That's my bet as well.
I think I recall you having this situation last year IIRC.
Old Mar 9, 2010 | 09:25 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
fuel pump relay.................
Old Mar 9, 2010 | 09:32 AM
RetiredSFC 97
Didn't think of that, but it could very well be and it is a cheap thing to try.
I had a Honda at one time that did that. Had mechanics changing ignitions and other things. I finally got fed up and told them to change the relay. Problem fixed.
So what may be happening is the relay is not priming the pump but after it is started it starts based on existing fuel pressure. Is that what you are thinking?
Old Mar 9, 2010 | 10:16 AM
jims1990vette
It will start all day, it's the next day I would have to prime it.
Old Mar 9, 2010 | 01:30 PM
jims1990vette
Thanks for the information, can you tell me where the fuel pump relay is located? Can I just purchase one at Autozone or should I go to the dealer to get the part?
Thanks again,
Jim
Old Mar 9, 2010 | 08:20 PM
jims1990vette
I just finished putting in the fuel pump relay and she started right up. Thank you all for your help.
Jim
Old Mar 9, 2010 | 08:25 PM
RetiredSFC 97
Jim
Yep coupguy nailed that one. first thing is always, "do you hear the pump run" if not change the fuse or the relay once you determine it is getting power.
The relay is a pain to get to but i see you found it.
Thanks for coming back and telling us it's fixed. it will help someone else in the future.
Old Mar 10, 2010 | 04:58 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Old Mar 10, 2010 | 05:04 PM
jims1990vette
Ok as I told you last night I put the relay in and it started right up, now I come home from work and I tried to start it and it will not start. Does that mean that I need to replace the fuel pump?
Old Mar 10, 2010 | 05:08 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
I beleive a bad ICM shuts off fuel to the engine, it did to mine.
Old Mar 10, 2010 | 06:07 PM
jims1990vette
Excuse my ignorance but can you tell me what ICM stands for.
Old Mar 20, 2010 | 09:09 AM
jims1990vette
I finally got my car fixed. Yesterday I replaced my distributor cap,rotor,coil and the ignition module, and started right up. but I wanted to wait until today to try to start it and sure enough it started.
To How can this be?........Help
