TB Bypass Mod ---> pics??
Old Mar 10, 2002 | 07:42 PM
dmalhi1's Avatar
dmalhi1
Default TB Bypass Mod ---> pics??
anyone have any pics of the Throttle Body Bypass done or any steps outlining it? i'm kinda clumsy when i went to attempt this. pictures and stuff would help.
thanks
Old Mar 10, 2002 | 07:58 PM
vader86's Avatar
vader86
Default Re: TB Bypass Mod ---> pics?? (dmalhi1)
if you havent done the 160 or 180 (seeing that youre in Canada) tstat yet, it would be a good idea to do them at the same time.
I dont have any pics but what you do is remove the accordian looking hose between the MAF and the TB. Then youll see two hoses coming out from underneath the TB. Remove them and mate them together with a piece of piping and two clamps.
Old Mar 10, 2002 | 08:07 PM
dmalhi1's Avatar
dmalhi1
Default Re: TB Bypass Mod ---> pics?? (vader86)
alright
now what are these two hoses underneath the TB connected to at the moment if they are not connected to each other?
and which tstat should i get? 160 or 180?
also how to do the MAF modification?
gosh i am such a newb when it comes to this stuff ;)
Old Mar 11, 2002 | 12:18 AM
LT4Mike's Avatar
LT4Mike
check out my website. I put pics and instructions on there when i did mine. Hope it helps.
Old Mar 11, 2002 | 12:55 AM
vader86's Avatar
vader86
the two hoses are connected to the TB itself
since youre in canada, id get the 180. You should ask others from the far north and see what they put in.
to do the MAF, remove the two clips holding it in place and the connectors underneath and pull out the MAF. Then cut out the two screens (one on each end).
Old Mar 11, 2002 | 01:38 AM
dmalhi1's Avatar
dmalhi1
alrighty, and since the hoses are plugged into the TB does that mean i have to plug up the parts on the TB that the hoses were connected to? i noticed on LT4MIKE's website he actually plugged them up but is that neccessary?
Old Mar 11, 2002 | 04:17 PM
LT4Mike's Avatar
LT4Mike
not necessary.... i mainly did it for looks..... would also help against dirt and corrosion....
Old Mar 11, 2002 | 04:56 PM
dmalhi1's Avatar
dmalhi1
Default Re: TB Bypass Mod ---> pics?? (LT4Mike)
ooh ok..... well since you put it that way ;) i better buy those caps too.
To TB Bypass Mod ---> pics??
