A/C-heater control problem
Old Mar 13, 2010 | 04:20 PM
Lenferg's Avatar
Lenferg
Default A/C-heater control problem
Having a problem getting air flow to direct through the vents in the dash on my 96 CE. Air temp works fine but comes out the defrost and floor ducts. After some time (5-15 mins) flow will come through the dash vents. This is especially annoying during hot summer months when waiting on cool air! Any Ideas on a fix?
Old Mar 13, 2010 | 04:54 PM
aminnich's Avatar
aminnich
Check the vacuum fitting under the pass side fuel rail cover first. If not that than use the search function, advanced search for "96 ac vents" in the C4 tech section and learn about the programmer under your dash. Hope this helps. ps--now you can ignore my response to your post on the other forum.
Old Mar 13, 2010 | 11:15 PM
Gary96's Avatar
Gary96
My 96 had the same problem. It is a common problem. Use the link below and go to post #13:
http://forums.corvetteforum.com/c4-t...l-problem.html
To A/C-heater control problem
