Window motor replacement
Old Mar 14, 2010 | 11:12 PM
BobRR3's Avatar
BobRR3
Default Window motor replacement
Hi, I need to replace the window motor on my 96. Before i get started, I wanted to know if i need to remove the regulator or, Can i get to the motore bolts leaving the regulator in place. ? how long should this job take ?
thanks
Old Mar 15, 2010 | 08:17 AM
runner140*'s Avatar
runner140*
thanks
On my 96', it took about two and a half hours...I work slow. And I took the regulator out. (changed the faucets yesterday in our bathroom...it took me an hour each.)
Old Mar 15, 2010 | 11:14 AM
jhammons01's Avatar
jhammons01
Bob, Not sure about the motor, but you can get the entire scissor style regulator from thepartsladi for ~$100
removing your old one and installing the new one....how long will it take you to get the door panel off?? Add about 15 minutes to that time as it is a super easy job.
To Window motor replacement
