Help! Engine stuck in high rev
Old Mar 17, 2010 | 05:25 PM
CorvetteCody's Avatar
CorvetteCody
6th Gear
Default Help! Engine stuck in high rev
I bought my first vette, an '85, a month ago. Today I was out driving and as I pulled into my neighborhood I noticed that my brake pedal was hard and the car wasn't stopping on command. As it finally slowed down I noticed that the engine was still reving up as if I had the gas pedal floored. I put it in park and turned off the engine, and when I turn it back on it goes right back to high rev.
Any ideas? I'm brand new to car maintenance, and have no idea what is causing this or how to fix it!
Thanks!
Old Mar 17, 2010 | 05:27 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
check for vacuum leaks first thing
Go into the engine bay and see if notice any cracked or broken hoses or anwhere there is a gasket. it's an air sucking sound.
That's the foirst place to start
Old Mar 17, 2010 | 05:37 PM
oschlomer's Avatar
oschlomer
one little vacum line can throw off everything.
Old Mar 17, 2010 | 05:38 PM
RRT vette's Avatar
RRT vette
I agree with checking vacuum leaks and possibly around the brake booster, but also check around the throttle body/butterflys spring.
Old Mar 17, 2010 | 06:05 PM
floridamale's Avatar
floridamale
vac line to brake booster
Old Mar 17, 2010 | 06:21 PM
rodj's Avatar
rodj
Is the throttle closing properly on the stop?
Worn TB's can hang up and not return to idle properly
Old Mar 17, 2010 | 07:17 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
You may have one of those rare Toyota Corvettes.
Old Mar 17, 2010 | 07:29 PM
RedLS1GTO's Avatar
RedLS1GTO
No fair. Stole my answer.
Old Mar 17, 2010 | 07:46 PM
RetiredSFC 97
Check all these things and then it's time to look at the IAC and TPS. (idle air control, Throttle position sensor)
And if you do not have one, get a Factory Service Manual.
Old Mar 17, 2010 | 07:55 PM
CorvetteCody
6th Gear
Lol... jrzvette, I actually thought that very thing after I got it stopped! Thanks, everyone for your input. I will check each of the things mentioned. As I said, I'm new to working on cars - when I check these vacuum hoses am I just looking for cracks or broken ones? Thanksf!
Old Mar 17, 2010 | 07:58 PM
RetiredSFC 97
You're looking and listening for leaks. Cracks, lines that may have worked loose. Start with that brake booster the guys mentioned. If you were out cruising that may very well be where it is if it's a vacuum leak.
Listen for the sound of a high pitch whistle. (that's the best way I can describe it) It's like a sucking sound
Old Mar 17, 2010 | 08:16 PM
katte's Avatar
katte
5th Gear
I think the problem is in Vaccum hosing.
BMW Exhaust
Old Mar 17, 2010 | 09:13 PM
CorvetteCody
6th Gear
Default Fixed it!
Thank you all so much for your help. I was looking for the vacuum hose on the brake booster you all mentioned and I noticed another smaller "hose" that was loose. I think it's actually a cable, not a hose. It runs from the cruise control on top of the battery toward the engine. Once I attached it and tightened it the idle went back down to normal. Anyone know what cable/hose this would be?
Again thank you - I'm new to working on cars and had no idea where to start.
Old Mar 17, 2010 | 10:10 PM
Chuck Tribolet's Avatar
Chuck Tribolet
If you knew that was the cruise control, you are getting car maint
figured out REAL FAST.
However, the cruise control cable being disconnected should not cause
a fast idle. You sure it wasn't the throttle cable? On my '87 they
cross over each other, and it would be real easy to mis-trace them.
The cruise cable connects a bit farther towards the US driver's side
than the throttle cable. Dunno about '85s.
Chuck
To Help! Engine stuck in high rev
