radiator question
Old Mar 19, 2010 | 09:57 PM
Disarray_kid's Avatar
Disarray_kid
Default radiator question
How easy is it to flush and clean out the radiator and everything that the coolant goes? Or should i say how hard?
Old Mar 19, 2010 | 10:11 PM
RedVette84's Avatar
RedVette84
It isn't hard as long as you pick up a flush kit. But I remember that kit leaked a little - watch out for the opti. But the garages have the power flushers that do work better.
Old Mar 19, 2010 | 10:13 PM
Disarray_kid
I got a L98 motor. So no opti for me. How much does a flush kit normally run?
Old Mar 19, 2010 | 10:15 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
+1 on kit
Old Mar 19, 2010 | 10:17 PM
Disarray_kid
Originally Posted by j-vette
+1 on kit
Sorry but im still yound don't know what +1 means.
Old Mar 19, 2010 | 10:18 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
I was agreeing that you should get the flush kit. Makes it easier.
Old Mar 19, 2010 | 10:20 PM
Disarray_kid
I see said the blind man to the deaf man.
Old Mar 19, 2010 | 10:21 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
$4
Old Mar 19, 2010 | 10:22 PM
Disarray_kid
$4
That is all there is?
Old Mar 19, 2010 | 10:23 PM
jon0108's Avatar
jon0108
just installed one of those on my 86. Gonna do the upper and lower hoses next, then eventually do a flush.
Old Mar 19, 2010 | 10:25 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
well I guess you could buy two...?
Old Mar 19, 2010 | 10:26 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
yup good stuff!
Old Mar 19, 2010 | 10:28 PM
Disarray_kid
Nope I don't need to buy two. Thank you for the help.
Old Mar 19, 2010 | 10:32 PM
jon0108's Avatar
jon0108
Peak makes their version also. Its identical to the prestone except the yellow parts are blue.
j-vette's Avatar
j-vette
St. Jude Donor '10
Well of course you don't need two. I just didn't know what you meant by:
Old Mar 19, 2010 | 10:52 PM
pologreen1's Avatar
pologreen1
You can open your spicket, and let it drain, then run a garden hose in it while it runs, that way you can run out all the junk too.
I expect some to complain or analyze this method, but is old school and works.
Old Mar 19, 2010 | 10:56 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
Flush kit goes against scale (back flush) and lifts more for better flush. JMO
Old Mar 19, 2010 | 10:57 PM
SQUIRMIN VERMIN 84's Avatar
SQUIRMIN VERMIN 84
From: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
old school works just fine....
Old Mar 20, 2010 | 12:34 AM
samsonb's Avatar
samsonb
I've read not to use those kits as it introduces ice cold water into a hot engine.
I say the best is to just dump the coolant from the drain plugs and radiator. Fill with distilled. Run engine. Let cool. Drain the water from the drain plugs and radiator. Refill with distilled. Run again. Then just dump it from the radiator. Keep doing this as long as you want. Then drain radiator. And start filling with straight antifreeze. If your system hold 14 quarts of coolant. Dump in 7 quarts of straight antifreeze as you already have distilled water in the block. Then burp it.
To radiator question
