Working under car
Old Mar 21, 2010 | 01:43 PM
womblesd's Avatar
womblesd
Default Working under car
When working under car, have you found it better to drive car onto ramps, or jack the car and place on stands?
Thanks in advance for your advice.
Dan & Linda Wombles
St. Louis, MO
Old Mar 21, 2010 | 01:53 PM
toptechx6's Avatar
toptechx6
Neither
Old Mar 21, 2010 | 02:09 PM
wnafly's Avatar
wnafly
Top, i could only wish:o
Old Mar 21, 2010 | 02:11 PM
toptechx6's Avatar
toptechx6
Sorry, couldn't resist.
Old Mar 21, 2010 | 02:31 PM
Aardwolf's Avatar
Aardwolf
I use jack stands. I don't have any ramps, I found long ago that they are to big and get in the way.
Old Mar 21, 2010 | 02:38 PM
Frizlefrak's Avatar
Frizlefrak
I have both...use ramps for oil changes and quick stuff, 6 ton jack stands on all 4 corners if I'm gonna be under it for a while or need more clearance.
Still looking for a nice used Kwiklift....but everyone within 500 miles of me thinks their 8 year old Kwiklift is worth the same as a new one. The ones 2000 miles away, of course, are reasonably priced. Go figure.
Old Mar 21, 2010 | 02:40 PM
pologreen1's Avatar
pologreen1
I have been using jack stands for the car, but grew tired of it lately, so I was going to buy or build wider ones for these this car, because it is too low to drive up them, and tires are too wide to fit in the tray of them, but I cut some planks and put them in the middle of my ramps, so the tires have and even space to rest on. Now I jack the car up in the middle and put both ramps under it, and I can use the stands for the rear.
I recommend ramps if you have them use them.
Old Mar 21, 2010 | 05:37 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
I've yet to find a set of ramps that you can buy that when you drive up on them... the car is high enough off the ground to really work under. You really have to make your own. So at this point unless your a rich guy ... or a tech like toptechx6 ... good quality jack stands are the way to go.
Old Mar 21, 2010 | 09:26 PM
frank1973's Avatar
frank1973
I use a set like the ones on this link. Work great for low clearance and wide tires.
http://www.literamps.com/car_ramps.htm
Old Mar 21, 2010 | 09:40 PM
RickF's Avatar
RickF
I have a set of the two piece race ramps that I really like. I do wish they were a little taller, I think they make a taller set that was more $.
I feel much better under ramps. I still use stands for the rear though.
Old Mar 21, 2010 | 09:44 PM
Jamie Lennartson's Avatar
Jamie Lennartson
Mine is to low for ramps.
I can back it up on ramps tho as i do to clean the diff and everythign else every year.
But to get to the front of the car i have to drive in the dirt and dig a hole jack it up and put it on stands.
Yeah ima ReDneCk
Old Mar 22, 2010 | 12:45 AM
pologreen1's Avatar
pologreen1
Most performance car ramps get the cars wheels 8-12 inches off the ground. But they are expensive in most caes. I use the old metal ones with planks on them. My tires are more than a foot off the ground, and the bottom of the car is plenty high off the ground. I can make it higher.
Old Mar 22, 2010 | 01:08 AM
kangi's Avatar
kangi
Yup, me too
Old Mar 22, 2010 | 07:58 AM
jlsru's Avatar
jlsru
Cruise-In V Veteran
I know what you mean about that.I finally ran across a local guy with a kwik lift for 400 bucks.I was really happy to get it.
Old Mar 22, 2010 | 08:24 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Jack and jackstands.
With some ingenuity I was able to get the rear end up high enough to do the rear hubs.
When possible I use a friends lift. It just wasn't possible this time though
Old Mar 22, 2010 | 08:29 AM
drmrman's Avatar
drmrman
Im fat... I have to use jack stands otherwise I cant fit my belly under...
Old Mar 22, 2010 | 09:14 AM
mrmtrtrnd's Avatar
mrmtrtrnd
Do you put the planks under the ramps to raise them or on top in the tire cradle area to get more clearance?
To Working under car
Old Mar 22, 2010 | 09:21 AM
Donne Trav's Avatar
Donne Trav
Originally Posted by toptechx6
Neither
If this is your home garage--I mean diiaam! You lucky guy!
Old Mar 22, 2010 | 09:26 AM
Donne Trav's Avatar
Donne Trav
[QUOTE=Frizlefrak;1573495366]I have both...use ramps for oil changes and quick stuff, 6 ton jack stands on all 4 corners if I'm gonna be under it for a while or need more clearance.
Ditto/with 3 ton stands. Sometimes the ramps do get in the way. How
about that photo at the "TOP"? WOW!
Old Mar 22, 2010 | 09:28 AM
joesgulfstream's Avatar
joesgulfstream
Yeah ima ReDneCk
why don't you just dig a big hole under the the car and work on it from inside the hole
