Bizarre - Tire Question
Old Mar 22, 2010 | 07:26 PM
Admrl94's Avatar
Admrl94
Default Bizarre - Tire Question
Ok, I've done my homework, waited patiently for spring, and ordered my new wheels. They arrived just as I expected.
18x10.5 rear, 18x9.5 front for my '94 coupe.
All wheel/tire packages I've seen for 18s feature 295/35 rear and 275/35 front....so when I called Discount Tire tonight to order said tire sizes, the guy was telling me their system recommends 275/40 fronts, not 275/35, in part because of load-bearing reasons.
My question: what's the deal? It sounds bizarre! I've got both front sizes there and can have either installed this coming Saturday.
Old Mar 22, 2010 | 07:57 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
I sure wouldn't use that 275/40 size.
That tire is approx. 1" taller in overall diameter than your original front tire.
275/40-17 = 25.66" approx. diameter
275/35-18 = 25.57" approx. diameter
275/40-18 = 26.66" approx. diameter.
You want to stay as close to the original diameter as possible.
Old Mar 22, 2010 | 08:05 PM
NMsharkracer's Avatar
NMsharkracer
From: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
Completely. Someone is blowing a little smoke!
Old Mar 22, 2010 | 08:36 PM
xole's Avatar
xole
I am running 295/35-18 on all 4 corners just fine on 10.5 rims. Next time I will probably go to 315's.
-D
Old Mar 22, 2010 | 09:13 PM
Admrl94's Avatar
Admrl94
Thanks for the replies.
It really threw me at the time because I was completely not expecting it...and he was pretty adamant. There's that moment of doubt even though you've seen something a hundred times.
He said they only move to 35 at 19" wheels. That's when I thought It wasn't just me anymore!
Old Mar 22, 2010 | 10:38 PM
jhammons01's Avatar
jhammons01
^^yeah, I got the smaller size on my 18" rears and it sux......Made first gear nearly worthless. as soon as I get the clutch out, it is time to shift.
To Bizarre - Tire Question
