It never ends!
Old Mar 26, 2010 | 05:36 PM
TheDudeMatt's Avatar
TheDudeMatt
Default It never ends!
Ok, just got finished installing my new Clutch Master Cylinder, no problem. When i went to go attach the rod from the MC to the Clutch pedal its such a tight squeeze i accidently extended the pedel out towards the driver seat. I heard a clicking noise similar to the clicking you hear when you tighten a zip-tie. I continued thinking it was nothing, but when i had everything hooked up. I noticed the sensor that lies agianst the clutch pedal doesnt hit the clutch pedal anymore.
Here is a picture of that sensor not touching the pedal.
My best guess on what happened was when i extended the pedal the threads on the sensor just got pulled out, maybe i could just screw it back in...
ANY SUGGESTIONS!?!?!?
Thankyou!
Old Mar 26, 2010 | 05:42 PM
nutz4c4's Avatar
nutz4c4
Just push it back in. It does not screw in.
Old Mar 26, 2010 | 06:20 PM
TheDudeMatt
Thanks worked perfectly you are the man!
Old Mar 26, 2010 | 08:46 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Glad it worked out.
To It never ends!
