Power Steering Foaming
Old Mar 28, 2010 | 03:23 AM
fltstone's Avatar
fltstone
8th Gear
Default Power Steering Foaming
My 93 C4 I power steering was whining and the reservoir was low so I topped it off. After letting it run for about five minutes I waited for it to quite down I checked the reservoir and it was full of foam. My C4 only has 48,000 miles and has been in the garage for about a year. What do you think my trouble is and how do I fix it?
Old Mar 28, 2010 | 08:29 AM
78pacer's Avatar
78pacer
Don't sweat it. Just find the leak. What you have is air trapped in the system. Turn your steering wheel stop-stop a few times. That will work the air out eventually.
Mike
Old Mar 28, 2010 | 10:01 AM
93v's Avatar
93v
Mike
I agreeIt happened to me once
Old Mar 28, 2010 | 04:04 PM
MK 82's Avatar
MK 82
What did you top it off with?
Old Mar 28, 2010 | 09:23 PM
jtc44's Avatar
jtc44
If foam does not go away look for a leak on sucktion side not always a P/S leak but but may be sucking air and causing foaming I wish I could spell it is called pump cavition
Old Mar 29, 2010 | 09:25 PM
fltstone's Avatar
fltstone
8th Gear
Thanks guys, After I let it run for awhile it sounds much better. I found one of the clamps leaking so I tightened that up. Hopefully that'll fix it.
To Power Steering Foaming
