Center cap security key?
Old Mar 30, 2010 | 07:06 PM
lawdog44's Avatar
lawdog44
Default Center cap security key?
I just bought a set of 1988 rims for my 1985 on Ebay. They arrived today and I noticed that you apparently need a security key tool to remove the caps from the rim which didnt come with my rims. Is this a universal type security tool I can find or am I up the creek in trying to remove the center caps off the rims?
Old Mar 30, 2010 | 07:14 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
did you get adapters for the wheels? I don't think the key is "universal" in that you will find it at autozone but maybe another 88 owner...
Old Mar 30, 2010 | 07:25 PM
lawdog44's Avatar
lawdog44
Havent got adapters, was hoping they would fit without them.
Old Mar 30, 2010 | 07:30 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
I think 88-96 had same sizes. You will need adaptors I believe...
Old Mar 31, 2010 | 02:51 AM
Movnviolation's Avatar
Movnviolation
You will most likely never find a key to match up. I had my key strip two locks on my caps. Had to get a hardened bit and drill the bolts and use easy out. Came right out.
I could not find locks so I used allen head bolts aluminum colered, and you can not see the bolts. They are not secure like a lock, however, my car is garaged and not a DD.
Good luck
Old Mar 31, 2010 | 07:41 AM
ottawabarber's Avatar
ottawabarber
Is this what you are refering too?
http://ecklers.com/product.asp?pf_id=55386&dept_id=195#
If this is them, then maybe one of the Corvette recyclers can provide the little wrench/key that is found in the center console or maybe a member has one laying around for sale.
I found this on Ecklers, but I am sure other vendors carry them and if you contact them they may have the key/wrench you need. I do recall someone had a link to a company that had them for sale and there was like 10 or so different styles/shapes you need to give them the number on the locking bolt head and they will ship you the one you need. Hopefully someone will chime in with that link for you.
Larry
UPDATE: I just found the company that can probably help with the lock. Here is the link to the website: http://www.mcgard.com/
Specific to our caps ( I think) Linky here
Hope this helps!
Old Mar 31, 2010 | 08:08 AM
lawdog44's Avatar
lawdog44
Larry
Hope this helps!
Yes, that is the center caps on the wheel, I will see what I can run down with this info. Thanks a lot!
Old Dec 26, 2023 | 02:35 AM
35yrannGers's Avatar
35yrannGers
1st Gear
what size Allen head bolts did you use?
Good luck
Old Dec 27, 2023 | 01:15 PM
1985 Vette's Avatar
1985 Vette
One of the first things I did to my 88 was to remove the locks on the wheel caps. The bolts I used were M10-1.5x25mm Allen head bolts. The Allen head uses an 8mm key, but I use a 5/16" key as it fits fine.
Old Dec 27, 2023 | 04:54 PM
BlackbirdZ07's Avatar
BlackbirdZ07
This thread is almost 14 years old, but I have a bunch of the original keys. If you're looking for one I may have it.
To Center cap security key?
