Lowering 93 coupe?
Old Mar 30, 2010 | 08:46 PM
lilredc4's Avatar
lilredc4
Default Lowering 93 coupe?
I have a friend who I have promissed to help lower his 93, Neither of us have never done this before and am concerned about the procedure. Anyone have any links to previous threads or links (yes I have searched) that may help or provide info on how to do this? Special concern about the mono-leaf spring and how to saftely remove and reassemble it. Any help or advice would be appriciated.
Old Mar 30, 2010 | 09:00 PM
Loby 1's Avatar
Loby 1
Old Mar 30, 2010 | 09:07 PM
jimg's'93's Avatar
jimg's'93
The easiest method for the rear is to purchase longer threaded rods holding each end of the mono springs. For the front, there is a method of removing, or shaving the wedges on each side of the spring. There really are a lot of threads with good detail on these procedures in here. I've never done it (Just removed my coils and replaced 'em with mono's) so I can't help too much...but I can lead you to the water
Old Mar 30, 2010 | 09:20 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
When you pop the lower A arm from the spring (after taking off the shock and sway bar end link) you will need LOTS of room to swing the A arm down. Support the spring with a jack when you release the final component holding the A arm up
Old Mar 30, 2010 | 09:23 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
http://webpages.charter.net/khasting.../lowering.html
To Lowering 93 coupe?
