Headlight Replacement
Old Mar 31, 2010 | 09:56 PM
barneystinson's Avatar
barneystinson
Default Headlight Replacement
Hey everyone. I just replaced my headlights with some Silverstars. The installation was easy, however every time after I use my brights the bright light indicator stays on even when the lights are on dim. Any ideas what it could be? It never did this before and I know everything is hooked up the same.
Old Mar 31, 2010 | 09:59 PM
jhammons01's Avatar
jhammons01
That's a new one...............
Old Mar 31, 2010 | 10:13 PM
barneystinson
Yeah, it's weird. I turn the headlights on and the bright light indicator is not on. I'll switch to bright and back to dim and the light stays on. I have not seen/heard of that before either.
Old Mar 31, 2010 | 11:13 PM
deerra's Avatar
deerra
Are they drawing more juice?
Old Apr 1, 2010 | 08:01 AM
runner140*'s Avatar
runner140*
New one on me. Might be worth a shot to disconnect the neg. battery terminal....then reconnect.
Old Apr 1, 2010 | 08:29 AM
drmrman's Avatar
drmrman
Try putting your stock head lights BACK in and see if it does it...
If it no longer does it then its an issue with the light.... If it contiues to do it then there is a short somewhere.
When corvettehid.com came and installed the plug and play HID set up on my car we were having issues with the high beam light staying on while the lights were on and it was a simple fix of switching wires to different terminals. In your case you DID NOT switch any wires so if there may be a short. That may cause it to read that its pulling more voltage and trip the high beam indicator...
Just a thought... I havent seen a head light wire diagram in AGES but Im trying to recall how we cured my issue...
Old Apr 1, 2010 | 09:11 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I've seen this happen on an 88 if you went to a different driving light bulb. Not the headlight but the foglight. Its been so long, but the main reason was the foglights are grounded through the high beam circuit (or something like that)
Churchkey's Avatar
Churchkey
I think you have an issue with one of the lights. Try disconnecting one of them & try it. Then reconnect & try the other to determine which light has the problem.
Old Apr 1, 2010 | 06:08 PM
redrose's Avatar
redrose
usual perp in this act is a bad ground from one lite...pull the connector off the bulbs one at a time / reconnect till the dash telltale chills, check the ground wire at that bulb.
Old Apr 1, 2010 | 07:05 PM
mrmtrtrnd's Avatar
mrmtrtrnd
I want to know the answer to this, I'm going to be putting Silverstars soon.
Old Apr 1, 2010 | 07:22 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Don't be afraid - just do it. I replaced the ones on my 92 with silverstars and no issues. The OP issue is rare.
Old Apr 1, 2010 | 09:56 PM
barneystinson
I have not had time to take the lights apart yet. I think I'll just be leaving it this way until we get a rainy day. As long as the dims and brights still work I am not too worried about it. I was curious if anyone else had this happen to them and I got some great answers. I'll let you know what comes of this as soon as I get a chance to work on it.
Old Apr 2, 2010 | 05:14 AM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
Disconnect the plugs on the back of the headlights and spray some WD-40 into them. Then plug them back up. That might help improve the connection.
To Headlight Replacement
