I have 90 that has a battery drain problem. The LCD fuse appears to be the problem. I have removed the Radio /cassette/cd unit already. The other items on the circuit are mostly behind the radio.The other items ,CCM, tone generator, courtisy light timer etc appear to be behind the redio. Whats the easiest way to access them. Thanks
I removed the dash top to get to the tone gen. There is no easy way to get to anything Just some things are a little easier than others. The allowed me to get to the chime unit and the cruise control module.
Actually, if you have the radio trim off all that's left is the air vents, lower dash panals and then there are 4 screws left holding the top in.
If you have the FSM it is pretty clear on the removal.
Regards Pop
