How do I
Old Mar 13, 2002 | 05:45 PM
jims_red_94LT1's Avatar
jims_red_94LT1
Default How do I
find out if I have an active fault code, also how do I pull the code? Thanks for the help.
:flag
Old Mar 13, 2002 | 11:53 PM
Jsailor24's Avatar
Jsailor24
Default Re: How do I (jims_red_94LT1)
I used a peperclip. You connect it between Aand B terminals -- i think :rolleyes: that theyre the 2 bottom right terminals on the OBD link. First you will get a code 13-- i short flash, pause, 3 short. -- this code will repeat 3 times, then if you have more codes they will do the same type of readout. If not, you will see another cycle of code 13s. Just connect the terminals and turn the key to the "on" position. :cool:
Old Mar 14, 2002 | 09:29 AM
jims_red_94LT1
Default Re: How do I (Jsailor24)
Thanks, its reading a code
H32
1.
The car won't start, don't understand why.
Jim
Old Mar 14, 2002 | 12:20 PM
chucks00's Avatar
chucks00
Cruise-In III & VI Veteran
This site may help. http://home.fuse.net/c4/ecm_codes.htm
To How do I
