passenger window problem
Old Apr 7, 2010 | 12:34 PM
womblesd's Avatar
womblesd
Default passenger window problem
On our 96, the passenger window will go up & down using the passenger button, but will only go down, not up, when using the button on the drivers door. I am assuming it is an electrical issue of some sort. Any ideas on how to fix?
Thanks in advance,
Dan Wombles
St Louis, MO
Old Apr 7, 2010 | 12:46 PM
Glock 23C's Avatar
Glock 23C
Dan, I have the same problem with my 95. However sometimes it will work but mostly it doesn't. I guess at this point it really doesn't bother me because it is easy just to reach over and hit the passenger button. If it is an easy fix, I would probably fix it. Maybe someone knows any easy fix. Obviously someone smarter than us. http://images.ibsrv.net/ibsrv/res/sr...ies/smile5.gif
Old Apr 7, 2010 | 01:11 PM
womblesd's Avatar
womblesd
I want to fix it, since I plan on having the car judged by NCRS this summer. They will deduct from the score if the window doesn't work correctly.
Old Apr 7, 2010 | 01:12 PM
Rocket22's Avatar
Rocket22
Default get out the voltohm meter and test the switches
Try bypassing the switch to check. There are a number of ways to fix these, just need to find the problem. You know it is connectivity, just need to find the break. I had corrosion on my ford explorer switch, so it took all of five minutes and some sandpaper to fix.
To passenger window problem
