Little help Please: 1992 Random Start
Old Apr 7, 2010 | 02:30 PM
wheelfast's Avatar
wheelfast
Default Little help Please: 1992 Random Start
Hey C4 Guy's and Gal's,
1992 Corvette w/35,000 miles
My car starts sometimes (more than not) and only clicks and will not start other times..........click-click-click ----> no go, try it an 1/2 hour later it fires up.
Any help would be greatly appreciated.
Thank you
Old Apr 7, 2010 | 03:55 PM
socalman's Avatar
socalman
St. Jude Donor '10
That sounds battery related. Check for loose connection on battery. Then check for frayed battery cables. If your battery is over 2 years old, I'd also have the battery checked.
Old Apr 7, 2010 | 07:31 PM
HerFirstVette's Avatar
HerFirstVette
I have a 93 and it would start cold everytime. Once it came up to temp though, it would turn over but not start. Sometimes it would try to fire, but a super rough/random chug was all it would do. I spoke to an expert and he said "unhook the neg cable for 10-12 minutes and reconnect". I unhooked it before dinner, cleaned and reconnected after, and it's run perfect ever since.
I was not completely confident at first, but now believe it was as easy as rebooting. I realize this is not the exact same problem you describe, but it's a no-cost start.
Old Apr 7, 2010 | 07:37 PM
Jamesnns's Avatar
Jamesnns
92 w/35K?
Wow.
Old Apr 7, 2010 | 10:27 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
click-click-click - could be the starter selenoid going
turn over and no start - icm & coil ask me how I know. I'm on my second coil (probably didn't need to change it the second time) and third ICM in 3 years.
Old Apr 7, 2010 | 10:30 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Thank you
Check ground wires.
To Little help Please: 1992 Random Start
