Correct wheels for 87 Vette
Old Apr 10, 2010 | 09:38 AM
djdeep73's Avatar
djdeep73
Default Correct wheels for 87 Vette
HI
Im trying to get a set of "sawblades" wheels for my 87 vette and was wondering since ive read so much info that these will fit on my vette but that i will need adapters.........then i also read that they will fit right on.........can someone help with this ? Do i need 4 adapters or just 2 or will they just fit with nothing at all ?
If i need adapters what size do i need and where do i get them from ?
Thanks-
sawblades
http://awesomecarauctions.com/upload...ner-785525.jpg
http://images.google.com/imgres?imgu...26tbs%3Disch:1
Old Apr 10, 2010 | 09:53 AM
Jamie Lennartson's Avatar
Jamie Lennartson
Originally Posted by djdeep73
HI
Thanks-
sawblades
Mine is an 87 and i have Sawblades they have been on there since 1996 no adapters bolted right on and are just fine!
Old Apr 10, 2010 | 10:04 AM
Jamie Lennartson
Bigger pics to give u an idea of how it looks.
And a video with a walk thru.
Old Apr 10, 2010 | 10:05 AM
socalman's Avatar
socalman
St. Jude Donor '10
Ok, edit after Hokie beat me to it. If you want the wheels to sit out like stock, use adapters. Also have to look behind the tire before changing to see if you have 3/4" clearance from brake lines, inner fender etc. Typically, You will need adapters on all 4 wheels- 18mm or 3/4". (you're going from 38mm backspace to 56mm) I don't believe they make adapters at 3/4", so bump up to 1" adapters on all 4 corners. Adapters bolt onto the existing hub and utilize new studs, vs spacers which is merely a disk and does not bolt on, also requiring changing all the studs to longer ones.
http://www.joby.se/corvette/div/corvette_wheels/
Old Apr 10, 2010 | 10:08 AM
Jamie Lennartson
What size tires do you have on the front and back ?
Front 255/40/17 rear 285/40/17
rodj's Avatar
rodj
They bolt on but notice how they sit in further than stock?
http://www.ecklers.com/product.asp?p...05&dept_id=263
Old Apr 10, 2010 | 10:19 AM
socalman's Avatar
socalman
St. Jude Donor '10
Doesn't say how thick they are.
Old Apr 10, 2010 | 11:16 AM
c4cruiser's Avatar
c4cruiser
The Eckler's adapters are 3/4" thick so they will place the wheel in the "proper" position in the wheel well. Other Corvette accessory vendors sell the same adapter so it may pay to shop around especially to save on shipping costs. As mentioned, a 1" thick adapter will work and not cause any problems.
With this size adapter,you can easily use the later 17x9.5" sawblade wheel and a 275/40-17 tire. This tire is very close in both diameter and tread width to the early 255/50-16 tire mounted on a 16x9.5" wheel. You won't have any clearance issues and the speedometer reading will not be off very much at all.
Old Apr 10, 2010 | 11:59 AM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
HI
Have you located a set yet? I have a set from my 93 that I may be looking to sell.
(sorry about the highjack)
To Correct wheels for 87 Vette
