Computer is same series; you won't notice any difference in the tune between the two years
1985-1986:
Duration @ 0.050 202/206 Lift with 1.5 R 403/415
LSA 114.5
1987 L98 @.050" 202'/206' Lift (w/1.5) .403"/.415" LSA 114.5
ok... how about spring pressures?... are they the same?
i would doubt this but if they are... im set to runn the roller.. if not.. all i need is a set of springs..
and if you would know( seams u have alot of info so share).. push rod length?
any info on that?
not that i want answers quick..but the machine shop man wants to knwo what i wana do... (dont wana keep him waiting.. busy man) so if you could get back to me asap that would be sweet
so your saying i cant use the pushrods i have.. (no problem)
im not using stock rockers... i have aftermarket full roller rockers i want to use.. still 1.5 but would rather use them? is that ok?
ur saying the spring pressure is the same for the roller and non roller setups? i find it hard to beleive that.. but if your saying thats the case.. anyone conferm? i allways though roller had to be stronger to hold the roller lifter onto the cam...
Spring pressure is more related to cam lift which in your case is the same on both
anyone have a spart 86/ 87 auto chip laying around?
only ask casue i dont know whats in mine.. yet to pull it.. and would like to have one incase anything was mess'ed with..(since mine is gonna be bone stock ... minus egr, smog crap,
They will work. You need to be sure they dont hit the valve cover. Sometimes the valve covers need to be modded for rollers.
well i think they will work.. i gotta test fit.. i allready cut the oil dripp things for the stock rockers off.. ( knew this from my dads 82 vette that he did that too.. with the full rollers..)..
only think i think it might hit is the oil breathers.. unless anyone can chime in here and tell me if i need to worrie about that ?
You can squeeze those with Chanel Locks for clearance, if you have to.
Anyone know if tge factory cams were billit cams ?? Also anyone know what the cam numbers were on the can itself??? I bought a 87 roller vette motor just wana make sure the cam is right ... The lobs were .415 and .405 ( prolly dirt ... ) please let me know asap if anyone knows... Thx.
