[Adhesive needed]Headlight shroud separation...
Old Apr 12, 2010 | 04:53 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default [Adhesive needed]Headlight shroud separation...
The RH headlight shroud has come "unglued"....
The flat part of the shroud (that meshes with the clam when headlights are closed) consists of two parts which are glued together:
1-outer part that is seen when HL doors are closed
2-inner part (sort of a fiber glass frame) bolts to the HL assembly
One corner of the "frame" (2) has come unglued from the outer part (1) so the outer part now does not sit smoothly in line with the clam and even catches on the clam preventing full headlight movement.
I want to find a glue that will seep in between the two pieces so that I don't have to try and fully separate the two parts completely.
Anyone have a suggestion, other than crazy glue, that might fit such an application??
Old Apr 13, 2010 | 01:07 PM
65Z01's Avatar
65Z01
Any feedback, pleasae??
Old Apr 13, 2010 | 01:25 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
To glue plastic to fiberglass use epoxy. Ensure you use gloves for this
Old Apr 13, 2010 | 02:57 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I used this to cover the headlight hole with fiberglass when I sold my headlights. I also plan to use it to hold my hood scoop on eventually.
Old Apr 13, 2010 | 04:17 PM
65Z01's Avatar
65Z01
Thanks for the replies...
Old Apr 13, 2010 | 05:09 PM
redrose's Avatar
redrose
jb weld (it is epoxy)...dirt or moisture is not helpful
Old Apr 13, 2010 | 05:41 PM
65Z01's Avatar
65Z01
Yes, getting it clean was the hardest part since only a corner and across the front of the frame had separated from the cover. Brake parts cleaner & coarse sand paper did a decent job though.
Finally, I used a "60-sec" epoxy (that is well named) where possible, a layer of JB Weld across the front of the frame and some crazy-glue to seep under the tight surfaces not accessable to the 60-sec stuff.
It already feels very solod; I think it may hold for another 20+ years.
I've filed away the ref to the 3-M repair kit for future reference and work on my "project".
Thanks again for all the feedback...
To [Adhesive needed]Headlight shroud separation...
