Need Help - Open Hood
Old Apr 14, 2010 | 07:42 PM
trader4fun's Avatar
trader4fun
Cruising
Default Need Help - Open Hood
Hello folks ,
I own a 1994 corvette , its been stored away for the winter .
No that i trying to get it going for the spring , I noticed that the hood cables are defective ( or hood latch on drivers side is sticking ) , such that i cannot open my hood . I cannot drive it as well as my battery charge is low .
I heard some folks say that there simple ways to get the hood open .
Any thoughts or ideas would help ??
Trader4fun
Old Apr 14, 2010 | 08:41 PM
Z51JEFF's Avatar
Z51JEFF
Ive heard that if you can get the hood open on the good side enough to grab the cable and pull on it it will release the bad side.
Old Apr 14, 2010 | 08:46 PM
pologreen1's Avatar
pologreen1
get a glimpse of what it looks like, and you will see you can hook it with something, and pull it out to the side. After you get it open, lube it up, and put some zip ties or something of the same idea on them, so in the future you can avoid this common problem. You would be screwed in an emergency other wise.
Old Apr 14, 2010 | 10:15 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Go to search and type in "emergency hood release" (with the quotes") and you'll find a whole lot of help. Here is one thread, there are others:
http://forums.corvetteforum.com/c4-t...se-cables.html
Old Apr 14, 2010 | 11:39 PM
HlhnEast's Avatar
HlhnEast
Probly mentions the Factory hood release tool in it. Its available from most Vette parts houses. Wasnt it designed by Gordon Killebrew to use at the factory?
Old Apr 15, 2010 | 08:54 AM
j-vette's Avatar
j-vette
St. Jude Donor '10
Originally Posted by trader4fun
Hello folks ,
Trader4fun
http://www.ecklers.com/product.asp?p...6&dept_id=1100
Old Apr 15, 2010 | 09:06 AM
ottawabarber's Avatar
ottawabarber
Here is an additional thread that I did last year with lots of photos of a permanent fix, not just the little zip ties. Maybe this will help you once you get it opened to prevent this again.
http://forums.corvetteforum.com/c4-g...with-pics.html
To Need Help - Open Hood
