I ran NGK TR55's in my LT1 for three years with no problems. I replaced them with a set of Autolite 606's. Still runs great. Spark plugs are spark plugs. Keep in mind their sole purpose is to create a arc to fire the fuel & air mixture. Don't waste your money on gimmick plugs.
change your wires also. makes a huge difference, i went from stock ac delco to some nice 8mm accels (yellow) you can get other colors but i think yellow looks better against the engine color...
My Corvette mechanic just put in a set of Accel plugs in my 87 and it runs great, no misfire at all. For my experience you misfire could be from a bad plug, injectors, fuel pump, fuel filter or not tuned properly. I would bring it to someone who does Vettes only. Oh and I have Taylor wires.
spark plugs, like wax, polish, and microfiber towels, are 90% hype and 10% fact. i doubt that you'll notice any difference in performance or anything, no matter what plug you use. just stick to the AC's, or any quality name brand plug and you'll be fine. BTW, i bought a set of NGK platinum's for my 90 - no reason other than i was at summit racing, and they were there... a lot of people have some negative things to say about bosch - i can tell you that i had bosch platinum's in my 85 and it ran great - ran them for 50K miles before i replaced them with another set of bosch platinum's. my sons running the 85 now, and he has no issues.
no need for any fancy tipped plugs either - 90% hype, 10% fact!!!
The thing I learned from the plug shootout is that you can spend nearly a 100 bucks for a set of plugs or 20 bucks, and the plugs that did the best, (although slightly) were the 20 dollar ones. My next set will be the NGK's.
You can get the NGK TR-55 Double Platinums for around $5 bones each. No need to drop $20 on platinum plugs.
I changed my cap rotor and plugs before I went on the Power Tour. It did have NGK's and i replaced them with ac delco rapid fires.
It seems to have a miss or something or the other. As it idles it'll go like Prrrrrrrrrhicupprrrrrrrrrrrrrrhicup etc. I don't know what the heck it is but I guess I will take them out and see if any of them are cracked or what have you. Only does it when it's hot though, not cold.
I also noticed the NGK's were gapped less than 035. That seemed odd to me.
I always check and reset the gap on my spark plugs. Though the regular NGK's have been pretty spot on at .035. Just about every regular AC Delco plug I've had has been off out of the box.
I checked them when I installed them but I think I'm going to take them out and recheck them and see if I cracked one or something.
Not mentioned so far is that exotic plug designs and heat ranges that aren't just like oem can cause low speed emissions to be dirtier, so if you have to deal with strict smog *****, like I do and don't want to have to change your plugs twice in a short period of time, I try to get oem or compatible replacements with a long lasting electrode/tip like the platinum AC that came in my LT1. Maybe I'd adjust no more than one heat range for no2 or forced induction..then it is more about the gap and timing at that point.
