No electrical power
Old Apr 21, 2010 | 04:18 PM
al martino's Avatar
al martino
2nd Gear
Default No electrical power
86 with problem with elec. widow opener on passenger side. Used screwdriver to pry open and shorted something out. Key was on and all dash lighting slowly went out. No power will come on at all. I need help!!!!!!!!!!
Old Apr 21, 2010 | 05:10 PM
C4boy's Avatar
C4boy
You probably shorted out a fusible link. Start by checking your fuses. Then break out a voltmeter and check your fusible links, which are located behind the battery.
Old May 12, 2010 | 07:19 AM
al martino's Avatar
al martino
2nd Gear
Thanks, It turned out to be the battery.
To No electrical power
