1987 Brake Problems
Old Apr 23, 2010 | 06:12 PM
858690Vette's Avatar
858690Vette
Cruising
Default 1987 Brake Problems
I have a 1987 with a 4+3 transmission. I drive it once a week and for about 25 miles. About three months ago, I noticed a slight drag on the front right wheel after applying the brakes. The drag lasts about 10 minutes if I don't use the brakes, and then it is normal. It drags again if I apply the bakes and is ok in about 10 minutes. The wheel runs a little hotter, but no smoke. I just had a mechanic replace the right caliper, brake pads, and brake hose, but it still does the same thing. I would appreciate any advice.
Old May 2, 2010 | 09:11 PM
858690Vette
Cruising
This weekend I pulled the electrical connection on the ABS control unit. The anti-lock brake light illuminated on the dash; however, there was no change in the problem. The right front brake still drags and releases after about 10 minutes.
Old May 3, 2010 | 12:00 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Wheel bearing getting sloppy?
To 1987 Brake Problems
