Battery issue
Old Apr 25, 2010 | 03:26 AM
eylesda's Avatar
eylesda
Default Battery issue
To some this is probably a dumb question.
Normally I disconnect the battery if I'm away for a couple of weeks, this time I forgot and it was dead flat.
I put the charger on low for 24 hours but would only charge to 10 volts, not enough to get the car going.
The battery was only 8 months old but I figured it was my fault so did'nt go the warranty route. Fitted a new battery and all ok now.
What would be the issue here? I thought batteries could be recharged from zero without a problem.
Old Apr 25, 2010 | 08:25 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
It's always possible that you had bad battery.
I would have taken it in for warranty replacement.
With that said, a new battery should be able to be left connected for 2-3 weeks without any issues at all.
If your battery is "dead" after that amount of time, you have a pretty large current draw causing it.
Maybe a hood light, console light, etc. staying on.
You shouldn't have to disconnect your battery.
My car has sat for as long 5 weeks without being driven, and no issues at all starting it.
If your going to let it sit for extended periods, a battery tender is a good option.
Old Apr 25, 2010 | 09:55 AM
Paul Workman's Avatar
Paul Workman
100%, every word.
P.
Old Apr 25, 2010 | 10:44 AM
1991-C4's Avatar
1991-C4
If your battery actually goes to zero volts (actually below 10 volts), it is dead with little or no possibility of bringing it back to life. Before you buy a new battery, you need to find out why it is discharging.
To Battery issue
