C6 rims
Old Apr 28, 2010 | 03:28 PM
wstrysko's Avatar
wstrysko
Default C6 rims
Anybody know the offset of the stock c6 rims?
will they bolt up to and fit a 86 coupe?
Old Apr 28, 2010 | 05:04 PM
floridamale's Avatar
floridamale
I believe they are 54 or 56 mm you will need adapters to make the fit right
Old Apr 28, 2010 | 05:30 PM
kawijames's Avatar
kawijames
2008 C6 Z06 replica 10 spokes for NON Z06.... 18X9.5 56mm offset. 19X10 63mm offset.
Fronts bolt up anywhere on 84-87 C4. Rears require spacer, no way around it.need a 1/2 more clearance to clear the LCA's
Old Apr 28, 2010 | 05:31 PM
wstrysko's Avatar
wstrysko
Is offset measured from where the wheel bolts up in
to the center of the car ?
Old Apr 28, 2010 | 06:02 PM
socalman's Avatar
socalman
St. Jude Donor '10
assuming you have the Z51 car w/ stock 9.5" wheels at 36mm-
Stock C6 is 8.5" fronts at 54mm and will fit almost perfect. You might want a 1/2" spacer to bring em out a hair.
The rears are 63mm on 10s, so you will need a 1" adapter
(adapters bolt to the hub and then have their own studs to mount the rim to- spacers have no studs, which means you will want longer studs in the hub to accomodate).
offset is the difference between the center of the wheel to the hub mount.
example- a 10" rim- center is 5". If the 10" wheel had a 'zero' offset, there would be a 5" backspace.
With a 63mm offset, it's aprox 2-1/2" further back from center, so you would add the 5" (center of the wheel) plus the 2-1/2", plus another 1/2" rim lip, for a total of 8" backspace.
Old Apr 28, 2010 | 06:06 PM
wstrysko's Avatar
wstrysko
Thank you all !
Old May 6, 2010 | 02:53 PM
wstrysko's Avatar
wstrysko
can i trouble you guy's once more,
i would like to put P325/30ZR18 on the back of my "86 coupe
will it fit ? if not, what will, i've heard 315's will
what size rim 10" or 11" and what back spacing will i need 38MM or 50MM
or something custom or a spacer / rim combo so they will not rub.
Thanks for the help !
Old May 6, 2010 | 03:41 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Where have you found a 325/30-18 tire?
I've searched at Tire Rack and Discount Tire, and neither of them show a tire in that size.
They have a 335/30-18 tire
The recommended rim width is 11.5" - 12.5" though.
Old May 6, 2010 | 03:51 PM
wstrysko's Avatar
wstrysko
woops,
just looking for the widest tire / rim that will fit
on my car without too much modification
Anybody know ?
Old Jul 18, 2010 | 07:30 PM
klug932000's Avatar
klug932000
sorry guys im a bit confused about off set and back space, i have a 85 and im looking at putting c5 rims (17 in) with 7 in backspacing and i believe the backspacing on a stock c4 85 is 6, so will i need a one in spacer? thanks guys
oh and roughly what does a spacer cost
Old Jul 18, 2010 | 07:56 PM
socalman's Avatar
socalman
St. Jude Donor '10
In short, yes, you will need adapters on all 4 wheels (1" will be fine). They run about $60 a pair and can be found on ebay.
To C6 rims
