Full throttle check..?
Old Apr 30, 2010 | 01:12 PM
Jamesnns's Avatar
Jamesnns
Default Full throttle check..?
I want to make sure that when I hit the pedal, my throttle is being pushed all the way forward to its max.
I can pop hood, see how far the thrt goes manuelly, then have wife put pedal to the metal and compare
Questions
If when stepping on pedal and its short, how to adjust so it hits max?
If there a diff, when stepping on the pedal and it doesn't go all the way, is it suppose to.
I don't want to make a mistake.
Old Apr 30, 2010 | 09:28 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
If it does not hit the stop there is a adjustment on the cable that you press and can then change the length of the cable. Might be different for the 91s then LTs.
