Rim Question ?
Old May 2, 2010 | 11:27 AM
daddysvet92's Avatar
daddysvet92
Default Rim Question ?
Sorry Guys, I was missing a digit there!
My rims now are both 17x9.5 and I have 275/40Zr17 for tires
My question is, the rims I'm interested in are fronts 17x9.5 and the rears are 17x11
Will I still be able to use my same tires that I'm using now for the 17x11 or will I have to buy 2 new tires to fit on these new 17x11 rims?
chris
Old May 2, 2010 | 11:40 AM
floridamale's Avatar
floridamale
Are you sure your listing the sizes right fronts should be 17x9.5 rears 17x11 ?
17 is diameter 9.5 or 11 is width
Old May 2, 2010 | 11:41 AM
NMsharkracer's Avatar
NMsharkracer
From: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
My guess is you're missing a digit and some spaces. 17 x 9.5 and 17 x 11 are normal ZR1 or Grand Sport sizes depending on the offset. They are different and early and late C-4's had different offsets as well. We need more information to tell you what will fit.
Old May 4, 2010 | 01:06 AM
daddysvet92
I re-edited my first post hope that is more clear, sorry for the confusion!
Chris
Old May 4, 2010 | 01:45 AM
rodj's Avatar
rodj
You could but what would be the point of fitting a wider rim only to fit the same size tire
Nothing gained except stretching tire tighter on rim with a reduction in ride quality.
Most go to 11's because they want the 315 or wider tire
Notice in this Yokohama listing ,
a 275/40/17 is recommended for a 8.5 - 10" rim
http://www.superjamie.net/garage/rimwidth.html
To Rim Question ?
