Need Help
Old May 3, 2010 | 11:08 AM
tjblake53's Avatar
tjblake53
Default Need Help
I have a 1986 c-4 my smog pump locked up can i remove it without affecting the engine or tranny i know i will have to get a shorter belt but i did not know if it will send any goofy codes or check engine lights will come on i planned to install headers and remove any how
Old May 3, 2010 | 12:24 PM
cfi's Avatar
cfi
I have an 89 with a stock L98 took mine off no codes, stumbles, misses etc. after a while I took everything else off and welded the manifold openings from the tubes. I have never had a miss step in the engine.
SOOOO it should be no problem.
Old May 3, 2010 | 02:18 PM
tjblake53's Avatar
tjblake53
Thanks for the input
To Need Help
