Im losted
Old May 4, 2010 | 08:29 PM
evil1knevel's Avatar
evil1knevel
Default Im losted
My vette has 91,000 miles
i have changed plugs,wires,filter, new gas filter
all runs great at start and cruising
but at stop in gear at lite it idles very rough
any suggestions
do u think my cats are plugged
Old May 4, 2010 | 10:56 PM
larry00's Avatar
larry00
Is the check engine light on ?
Have you checked the codes ?
Only need a paperclip to read codes and you can likely find the key to the codes in our tech section.
Could be an Idle Solenoid issue too !
You need to include the year for anyone to make a good guess !
Oh yeah bad gas will make one black smoke and Idle rough !
Old May 4, 2010 | 10:59 PM
Tommy T-Bone's Avatar
Tommy T-Bone
St. Jude Donor '06-'07-'10-'11-'12-'13-'14
Ohmed your injectors? A new set of injectors took care of my recent rough idle problem. Good chance someone will chime in on troubleshooting your problem.
Old May 4, 2010 | 11:25 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Good chance you have sticky/plugged injectors. Ohming them will tell you if they have bad coils, but won't show if they are plugged or sticking. Also check for vacuum leaks and a sticky or leaking egr valve.
Old May 5, 2010 | 12:40 AM
jfb's Avatar
jfb
An ohmeter will only find GROSS injector coil failures! An ohmeter will not find an injector with a turn to turn short in its coil and this kind of failure will prevent an injector from working. This is true because injector coils are pulsed. You really need an impedance bridge to conclusively electrically test injector coils. I found one bad injector with an impedance bridge on my 87 vette and my ohmeter said it was exactly like the other 7 injectors. I'm not saying don't use your ohmeter, I merely pointing out that an ohmeter isn't a definitive test.
Old May 5, 2010 | 07:00 PM
Old87owner's Avatar
Old87owner
Mine wouldnt start after driving it. It left me flatbedded at of all places my insurance company.
It ran rough before that, but I just figured it was from sitting for a few weeks. Then the flatbedding.
Found out, my EGR was stuck open. Replaced that and now my car runs better than ever.
So EGR valve is one possibility. Every once in a while, i will get ambitious and check my vacuum lines, once in a while I find one that is brittle or cracked and replace it.
Old May 6, 2010 | 05:37 PM
evil1knevel
Ill change the egr value
and check for air leaks
is it ok to put in injector cleaner and what would you suggest
Old May 6, 2010 | 05:38 PM
evil1knevel
Funny
sometimes it idles great
and sometimes I think its going to stall at idle waiting for s lite
Old May 7, 2010 | 02:18 PM
avgjoe's Avatar
avgjoe
Mine did that and it was the O2 sensor but it left a code. Do you have any codes?
Old May 7, 2010 | 02:19 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Clean the IAC just in case. It's cheap and should be done anyway.
To Im losted
