Jacking and jackstands on a C4.
Old Mar 17, 2002 | 09:36 AM
78Vette-SA's Avatar
78Vette-SA
Default Jacking and jackstands on a C4.
Could anyone tell me the correct procedure (if there is one) for jacking up a C4 (96 Coupe) with a hydraulic floor jack and jackstand placement? My 78 is easy, this one I haven't done yet but want to get under there the right way.
I know where the jacking points are when using the scissors jack, but am a little nervous about doing it with a floor jack and stands.
Thanks!
[Modified by 78Vette-SA, 8:37 AM 3/17/2002]
Old Mar 17, 2002 | 10:26 AM
JonM's Avatar
JonM
Default Re: Jacking and jackstands on a C4. (78Vette-SA)
Use the center crossmember in the front...you can use the same crossmember for your stands...On the sides, use a piece of 2x4x4 (some use a hocky puck)on your jack cup....jack it up just beyond the markings, then you can place your stands under the rear.
Old Mar 17, 2002 | 10:58 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Jacking and jackstands on a C4. (JonM)
What I do is place a 4 x 4 on a floor jack under the spare tire and jack it up from there. I place the jack stands on the frame nearthe gas tank.
For the front I drive the car up on 2 x 4's(to gain a little lift) I then jack up by the front crossmember and place the jack stands on the frame by the sway bar attachments.
Old Mar 17, 2002 | 12:24 PM
Bluevette85's Avatar
Bluevette85
Front: jack up in middle of crossmember and place jackstands on each end of crossmember.
Rear: 2x4 along sides, jack up then place jack stand.
Old Mar 17, 2002 | 12:33 PM
Rob 93ZR-1's Avatar
Rob 93ZR-1
From: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Re: Jacking and jackstands on a C4. (Bluevette85)
If you jack from the frame point behind the front tires, you will pick up the entire side of the car you are jacking. that way you only have to jack it in two places to get it off the ground. :seeya
Old Mar 17, 2002 | 06:42 PM
78Vette-SA's Avatar
78Vette-SA
Thanks again everyone. Couple of great ideas. :seeya
Old Mar 19, 2002 | 08:10 PM
Marlin in Minn's Avatar
Marlin in Minn
Default Re: Jacking and jackstands on a C4. (Mr Mojo)
Mr Mojo,
How long does the 4x4 need to be? The width of the spare tire? Would this
provide enough height to be able to change the exhaust system out?
Old Mar 19, 2002 | 08:12 PM
Mr Mojo's Avatar
Mr Mojo
Default Re: Jacking and jackstands on a C4. (Marlin in Minn)
Marlin, I just had one laying around, it's about the width of the spare tire carrier. I jacked it up high enough to place the jackstands and I yanked out my old exhaust and installed the new one.
Old Mar 19, 2002 | 08:32 PM
Sharky Guam's Avatar
Sharky Guam
I had so much trouble with jacks and stands on our vettes. I just ended up buying a two post lift for the house garage. I have a four post model at work just for my toys. They are not that expensive these days. :chevy
To Jacking and jackstands on a C4.
