a/c controls
Old May 10, 2010 | 07:18 PM
jim dodd's Avatar
jim dodd
Default a/c controls
a/c wont turn off ,fan will turn down but wont go back up it blows cold air temp control works but if i want to take the top out windows down i would to be able to turn it off thank you . 96 lt1 jim
Old May 10, 2010 | 07:28 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Take a look at this thread and see if it might help.
http://forums.corvetteforum.com/c4-g...on-repair.html
Old May 10, 2010 | 07:48 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
The link that RollaMo-LT4 gave is a good one.
I had that problem with my 94. I could turn the heat up, but not back down. Most of the buttons on the right side didn't work very often. Sometimes they would but most of the time they wouldn't.
I followed the directions in that post and it has worked perfectly for over a year now. The directions were very clear and it was easy to follow. I took my time and it only took me about an hour.
Good luck.
Old May 10, 2010 | 10:29 PM
jim dodd's Avatar
jim dodd
Default a/c
thank you RollaMo-lt4 icoped they thing you sent me ill try it this week end hope it works . people like you make this forum what it is .i hope that some day i can help someone the same way thanks again
To a/c controls
