same old question. is it the opti?
Old May 15, 2010 | 05:49 PM
littlesk8cracker's Avatar
littlesk8cracker
Default same old question. is it the opti?
car is a 94 convert 6 speed. has all new plugs, wires, coil, tune up etc done in the past few months. car was fine last night then i got caught in HEAVY rain drove through it for about 5 minutes then parked the car and went into a store. came out 15 minutes later and started car and its now hesitating and missing. sat outside in the sun all day and still same problem. so is it the opti? idk what else it could be, esecially because it happened after driving though heavy rain. if it is, wheres the best place to get a genuine acdelco opti? i dont want an msd or any cheap aftermarkets. thepartsladi store is empty, so where would be my best option? id like to spend under 350 if thats possible? thanks!
Old May 15, 2010 | 06:46 PM
timmy 93's Avatar
timmy 93
Don't sound good for the opti. You need a factory service manual and follow the chart. Pull codes DTC 36 and DTC 16 are bad opti codes. Jegs and Summit Have good selection of Opti $350. won't be enough for the GM #10457702 it's $520. MSD is $475. it's vented. I think yours is a non-vented. Shop around good luck ,Tim
Old May 15, 2010 | 07:10 PM
littlesk8cracker
zip-corvette has a delphi one for 370. is this the real deal?
Old May 15, 2010 | 08:04 PM
deerra's Avatar
deerra
I installed the MSD and am very happy with it. I think it's worth the extra cost.
Old May 15, 2010 | 08:15 PM
jabez's Avatar
jabez
+1
Old May 15, 2010 | 11:46 PM
littlesk8cracker
iv heard of alot of people having bad experience with the msd. original lasted me this long, id use another. does the zipcorvette delphi one look good?
Old May 16, 2010 | 07:53 PM
littlesk8cracker
ordered a delphi optispark from zip-corvette, and a meziere 55gpm electric water pump from summit racing. hopefully they come asap so i can get this straightened out
Old May 16, 2010 | 07:54 PM
littlesk8cracker
o, and pulled the codes using the paper clip method. 0 codes showed up
To same old question. is it the opti?
