check engine light issue
Old May 16, 2010 | 05:02 PM
ZO6TN2.9's Avatar
ZO6TN2.9
Default check engine light issue
About once a month when I start my 85 the check engine light will come on . If I drive it this way it will just sputter down the road. All I do is turn the ignition off ,restart , the light goes off and it drives fine. Any ideas on what would cause this.Thanks , Rich
Old May 16, 2010 | 06:38 PM
1800Wing's Avatar
1800Wing
Flatulent Dwarf
Does it set a code ?, or clear it from memory when it runs like it should ?
later, tiny
Old May 16, 2010 | 07:34 PM
Muffin's Avatar
Muffin
If the light came on the ECM should have a stored fault code. Pull the code and post it here. The 85 will record several different intermittant codes if certain sensors go out of normal limits. That may be what you are seeing. Pull codes to be sure.
Old May 17, 2010 | 02:23 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I don't think she has topped Vanessa Williams yet.
My '88 IROC-Z occasionally does the same thing; there is no stored codes.
Now, following the engine rebuild, the '88 Vette is doing the same thing...
Old May 17, 2010 | 04:23 PM
1st87's Avatar
1st87
there are 2 relays on firewall behind battery-napa stocks them-but anyway i changed them on my 87 and problem solved and idiot light went out...there sidebyside on mine, i don't know if yours is the same--should be...
Old May 17, 2010 | 05:03 PM
ZO6TN2.9's Avatar
ZO6TN2.9
thanks for the info
To check engine light issue
