Convertible hatch question
Old May 18, 2010 | 09:23 AM
AC13's Avatar
AC13
Default Convertible hatch question
Has anyone run into this ? Sometimes, not always, after I fold the roof into the back , when I go to close the hatch only one side catches and the other side stays slightly up. If I close it from the drivers side the passenger side doesnt catch and vice versa. If i push it down from the middle it seems whatever side hits first will close. Again, this doesnt happen all the time.
Is there something I may be doing wrong? Is there a proper way to close the hatch?
Thanks for the time,
ac
Old May 18, 2010 | 09:29 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I no longer have a C4 convertible so I am unable to go out to the garage and look. It could be something as simple as lubrication. A shot of WD40 might be all you need.
I never had that problem with either the 87 or 96 verts that I owned unless I had failed to use enough force to close the lid or if I had not fully folded the top.
I read a tip for those of you with plastic rear windows. It said to put a rolled up towel in the "crease" when you lower the top. This keeps the window from rubbing against itself and eliminates the ugly scratching and hazing. I always used a cheap beach towel on the 87 after reading that.
Good luck!
Old May 18, 2010 | 09:35 AM
AC13's Avatar
AC13
I have a 95 with the glass window. I just had the roof replace about two weeks ago so I cross my fingers everytime I lower the top.
I know sometimes the wire for the rear defrost lays across the latch and I have to move it before I shut the hatch.
I will give the oil a shot also.
Old May 18, 2010 | 10:30 AM
Jamesnns's Avatar
Jamesnns
Yea..once in a while.
I found that making sure the locking levers are fully closed and then I push down on the top too bfore closing.
Old May 18, 2010 | 11:00 AM
Larry/car's Avatar
Larry/car
The only time mine didn't close both sides was when I babied the lid and didn't use enough force to close it.
Old May 18, 2010 | 12:11 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
Old May 18, 2010 | 03:02 PM
betyelou's Avatar
betyelou
Old May 18, 2010 | 03:09 PM
pologreen1's Avatar
pologreen1
no. either you are not setting your top down in all the way properly, or the rubber adjusters on the deck lid, are set wrong
Old May 18, 2010 | 03:16 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
My passenger side would not always close, when I closed it from the drivers side. I put some lithium grease on the latches and lubed the cable where it connected and this seemed to take care of it.
Old May 18, 2010 | 06:55 PM
ks5shooter's Avatar
ks5shooter
St. Jude Donor '10-'11-'12-'13
A light grease does the trick
To Convertible hatch question
