Need some help!!!
Old May 23, 2010 | 06:53 AM
airewood@verizon.net's Avatar
Default Need some help!!!
I noticed a small crack starting at a rivet that is located on the flat surface where the hood comes down on drivers side. It has extended across the flat and is now starting down the side above the vents. Need to get it stopped but not quite sure how to or what to use.
Any suggestions???
