My 1990 Corvette runs great, NO mechanical problems. Everything about the car is in perfect shape except the DASH LIGHTS do not work.In addition, the SEAT BELT and CHANGE OIL LIGHT--- STAYS ON and I can’t reset set it. The air conditioner works great, the horn blows, the inside door lights and map lights work. Have checked all fuses.
I put in a new ECM, which did not fix it. Now I am told that it is probably the BCM. However, in some of the online forms I have read, it seems that if there is a problem with the BCM that the car will not run right. Any help or suggestions you have would be appreciated.
thanks,
Johnnie
