Disable LTPWS
Old Mar 18, 2002 | 11:18 PM
C4Cvette's Avatar
C4Cvette
Default Disable LTPWS
How can I disable the tire pressure warning system? I know that I can just pull the light, but is there another way?
Old Mar 19, 2002 | 11:07 AM
RFUNRED1's Avatar
RFUNRED1
Default Re: Disable LTPWS (C4Cvette)
You can pull the fuse, but that will also disable your cruise control. I just went through that because of two mangled tire pressure sensors because of a wheel swap. Just pull the bulb, it's easier.
Old Mar 19, 2002 | 08:00 PM
JHammer's Avatar
JHammer
Why do you want to disable it?
Do you run tire pressure low enough to activate the sensor?
:confused:
Old Mar 19, 2002 | 09:27 PM
C4Cvette's Avatar
C4Cvette
got new rims and no sensors. I am selling my rims w/ sensors to a friend that needs a couple of sensors and the rims and tires are in good shape. I'm not worried about the LTPWS working or not. I was the car so often, I will noice if a tire gets low.
To Disable LTPWS
