87 Trans
Old May 27, 2010 | 10:36 PM
phlounda's Avatar
phlounda
Default 87 Trans
Lost the trans in my 87 coupe the other day. Put it in gear and the motor revs but the car goes nowhere at first then it slowly starts to roll.
Any ideas?
Thanks,
Ed
Old May 28, 2010 | 12:23 AM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Originally Posted by phlounda
Any ideas?
Thanks,
Ed
First one is that it might be helpful to know if it's an automatic or manual...
Noises???
Old May 28, 2010 | 06:17 AM
Pete K's Avatar
Pete K
Any ideas?
Thanks,
Ed
I would fix it.
Old May 28, 2010 | 08:51 AM
snoopdan's Avatar
snoopdan
rebuilds of 700r4's arent much....unless you get it built for racing.
Old May 28, 2010 | 09:23 AM
Pete K's Avatar
Pete K
They are in his home state. Everything up there costs an arm and a leg.
Old May 28, 2010 | 09:27 AM
snoopdan's Avatar
snoopdan
that sucks. Its dirt cheap where I live, hell ive had guys at the track offer to rebuild mine for free just to get the practice
Old May 28, 2010 | 09:43 AM
Relic's Avatar
Relic
MA like CA is just leading the way. That's going to be "spread around" to the rest of us soon enough.
Old May 28, 2010 | 08:14 PM
phlounda's Avatar
phlounda
it an automatic. No warning, just no go.
Old May 28, 2010 | 08:16 PM
pologreen1's Avatar
pologreen1
I would fix it.
I bet you could
Old May 28, 2010 | 08:31 PM
Pete K's Avatar
Pete K
First thing to do is check the fluid level. If the filter is clogged, fell down or cracked, it could be sucking air.
If the car works fine in reverse, this is not likely the case.
If you have no forward, or reverse check the fluid level with the engine off, then start it and check again. If the level stays the same the pump broke, the flexplate bolts fell out, or the converter broke.
To 87 Trans
