oil pan ?
Old Mar 19, 2002 | 10:34 PM
crazyC4's Avatar
crazyC4
Default oil pan ?
Ok guy's I need to know one last thing about the dam pan. Do I need to torque the bolts to certain degree or not. Do I juste bolt them down. I called Chevy they said they cannot hepl me.Thanks
Old Mar 19, 2002 | 11:17 PM
CG77VETTE's Avatar
CG77VETTE
Default Re: oil pan ? (crazyC4)
I checked the Helms manual for my '86 L98 and here's what it calls for:
Oil Pan to Crankcase (1/4-20) 9 N m ( 80 lb. in.)
Oil Pan to Crankcase Nuts 19 N m (165 lb. in.)
Oil Pan Studs 9 N m ( 80 lb. in.)
I'm not sure why they show three different applications but I hope this helps. I tried to determine what the difference was and the only thing I see is that the Helms manual shows manual tansmissions using nuts and automatic transmissions using studs. Maybe someone else can chime in.
Old Mar 19, 2002 | 11:22 PM
crazyC4's Avatar
crazyC4
Default Re: oil pan ? (CG77VETTE)
Thans for the hepl, anything is good at the moment.
Old Mar 20, 2002 | 08:47 AM
No Go's Avatar
No Go
The reason the difference in torque values is due to difference size of hardware. There a 4 larger studs/nuts at each of the corners and the stuff in between are much smaller bolts (couple of studs/nuts too).
Notice those are inch pounds-so very small values.
To oil pan ?
