changed thermostat
Old Jun 11, 2010 | 07:23 AM
1st87's Avatar
1st87
Default changed thermostat
dam that was fun! changed the thermostat on the 87 yesterday. only took 2hrs....only problem was relining up the throttle body. but mission accomplished. i can see now where mechanics take advantage of some vette owners. but if you can do it yourself then enjoy....i did..
Old Jun 11, 2010 | 08:02 AM
runner140*'s Avatar
runner140*
Enlighten me....I have a 96' and have changed the T-stat several times.
What does the throttle body have to do with the thermostat on a 1987?
A t-stat change takes 20 minutes on a LT1.
But....a plug, wire and opti change is a four hour job on a LT1.
Old Jun 11, 2010 | 11:04 AM
1st87's Avatar
1st87
in order to get to the rear bolt on housing its easier to take the body off. made it easier to complete. took my time though-probably could have done it sooner.
Old Jun 11, 2010 | 12:36 PM
slickfx3's Avatar
slickfx3
doing mine tomorrow, the one that in it acts weird, I drilled it and it's a 180 should I have gone with a 195?
Old Jun 11, 2010 | 12:41 PM
samsonb's Avatar
samsonb
I stick with a 195 as that is stock. You can get thermostats that have a giggle valve already in it, which helps let air bubbles pass. I believe the Duralast have giggle valves in it.
If you go with a fail safe, some people have problems with those getting stuck open too easily.
Old Jun 11, 2010 | 03:10 PM
floridamale's Avatar
floridamale
I'm sorry that is a 30 minute project tops
But it's great to know you are turning your own wrenches
It's a 2 job
I have the TB water hose by-passed so it's a easy on R & R
Old Jun 11, 2010 | 03:11 PM
floridamale
On a L98 it's a little in the way eaiser, to remove the TB
To changed thermostat
