Alt issues?
To start off, i bought a new battery, but hadn't driven the car for some time and stupid me didn't disconnect it! so the battery was practically dead! read 2Volts.
anyway i jumped it and all was good! now reading 14+ volts while running, so i am assuming alt is ok!
Now my mechanic has told me that the alt is to keep the battery charged, and when low it should take about 20 mins to charge up! (this is with most cars), however i have been told on this forum that the alt should not be used to charge a battery!
Anyway i thought i would try it so i left the car idling for about 10 mins, then it just shut off! wtf? could this be that the battery just couldn't cope, or the alt is stuffed, or that it may have got too hot and turned off(i wasn't in the car so not sure on temp)?
Anyway any help would be great! thanks
No i didn't disconnect anything, just ran the car then all of a sudden it died! and battery was enough to pwr window up, but no lights on dash!
Thinking the alt. maybe working intermittently? brushes worn out?
how much for a new alternator is the US?
At risk is cooking the diode pack (rectifier). Heat resulting from unusually high current load, is the issue. Charging a dead battery will
the alternator's output capacity. Electronic devices deteriorate with heat, and if the rectifier is on it's last legs anyway, max output might put it over the top. And, if the ambient temperature is high (e.g., hot engine with the hood closed), the heat situation is exacerbated. So! In addition to a possibly injured battery, now you would be facing replacing/repairing the alternator!If you did charge the battery with the alternator and the alt survived (probably would have), you're in luck - tho you might have aged the rectifier in the process. You might want to see if there is an excessive current draw when the car is not running - causing the battery to drain. (Something like 20 mA or less wouldn't concern me: 50mA would put a furrow in my brow, and 100+ would prompt me to pulling some fuses to isolate the leak! JMO)
I keep all my vehicles charged using a Battery Tender. There are several other good ones, and I've even built my own, on occasion. (My personal favorite is their 800mA waterproof unit.) More than just keeping the battery charged, they go a long way toward preventing lead sulfate from forming on the plates - the real killer of lead-acid batteries.
Hope this helps. Come browse the ZR1 Net Registry some time. All are welcome.
P.
You can do it yourself by pulling part of the body behind the front wheel, specifically; the lower left front fender panel (with the vent).
A torx bit is required as some of these are torx screws and you don't need to pull it completely off, just loosen the screws on the front part behind the front wheela and remove the top and bottom bolts on the rear part, so you can get the battery past it sideways.
i agree not a good idea too often!
How can i check to see if there is a current drain?
The battery did not charge up at all as after the 10mins of running it it was barely enough to operate the pwr window!
I am thinking the alternator must have been gone when i bought the car
To all the other guys posting, my battery was brand new! AC delco, cost me $300AUD, was left in the car for only 3 months max and now needs a jump to start car! Yes i have swapped the battery over before, not too bad of a job!
Can these alt. be rebuilt, new brushes etc?
You need a Volt-Ohm meter that has a ampere and a milli-ampere scale. Disconnect the battery terminal - either one, but only one - from the battery. Refer to your meter's operator's manual and set the ammeter for the highest scale it has. Then put the probes between the open battery terminal and the cable that was attached there. (If you removed the (+) terminal, put the red meter lead on the (+) terminal and the black lead on the connector of the cable the was removed. But, if you removed the (-) terminal, put the black probe on the negative side of the battery and the red onto the connector of the disconnected cable.)
Most meters have a separate 10A scale configuration, and under normal situations the current may not register, or be very low...A GOOD thing on the 10A scale! A milliampere = 1000th of an amp and we're hoping for 25 milliamperes or less in most cases. There are exceptions, so you might refer to your FSM to see what range is normal for your particular car.
10-minutes charge time in the car, in a case like this, is not enough of a charge time. When a battery has not just only been discharged, but severely discharged, their normal behavior changes a bit - as does their life expectancy, I find. Two volts on a relatively new but severely discharged 12-volt lead acid battery is an indicator of a hurt battery. And, it will require the aid of a good battery charger - perhaps one with a de-sulfating mode - to restore it to some (if not diminished) useful life. See if a good over-night charging on a good battery charger doesn't bring it around.
Yes, with a good kit. A good kit will have new bronze bushings as well as a new rectifier/regulator. Really - nothing to 'em to freshen up if you have the right kit.
If the car has been sitting for an hour since being shut off, is cool, and the engine not running, the voltage across the terminals should be aprox 12.6 or so. There are (6) 2.2-volt cells in a 12 volt battery, and if you have a voltage reading that is low by approx 2+ volt increments, then you have a bad cell or cells. E.g., as mentioned, 10 volts on a battery that was recently charged is approx 2 volts low and probably one cell is definitely bad. At that point, the battery IS junk.
An otherwise healthy, but simply discharged (car) battery will still read 12 volts with NO LOAD attached. (Up to 20-25mA would be considered "no load", in normal circumstances.) However, the voltage across the terminals of lead acid batteries under significant load can go conciderably lower than 12 volts - ask anyone with a trolling motor! But, I digress...
Well, if the voltage measured between the battery posts ("cold") reads approx 14.6 ± a few tenths with the engine running and no accessories running, or about 13.5 volts after the car is warm and been running for 30 minutes (normal driving) or so, the alt = fine. That isn't a problem.
If you want some links to the parts (off a guy from the big auction site)- send me a pm. I just bought the brush kit, regulator and he threw in new bearings, for around $20. Even comes with the needle to install the brushes (pull the needle out of the little hole in the back after screwing down the brushes).
Well i guess my alt is ok then, that's a relief! will try and recharge the battery and see how that goes! and will check for any drain!
Wonder if i can take the battery back to the supplier? i have had it for over 3 months now, maybe more! but i am thinking it was down in cells when i bought it! ya see i live in Western Australia and there is not a lot of demand for those batteries, so who knows how long they have been on the shelves!
SoCalman: thanks mate for the offer, if it turns out that it is the alt, i might get that addy of you!
