4+3 Fun
Old Jun 20, 2010 | 12:12 PM
yellow88's Avatar
yellow88
4th Gear
Default 4+3 Fun
My O/D on my 4+3 won't engage. I think I have a bad relay, but I can't find it to replace it. Any help on it's location in the car would be great!! Thanks
Old Jun 20, 2010 | 04:39 PM
1stvet87's Avatar
1stvet87
Default on 87
on my 87 and i believe the 88 it is on the firewall drivers side above lt exhaust manifold. there should be 2 relays held to a bracket with 10 mm nuts. one faces forward, the other should face to passenger side. The front one (facing front of car) should be the OD relay. The other should be the fuel pump relay. Check wires going into relay, due to heat they tend to loose insulation and could touch causing problems. Also OD will not work until the ECM see's 140 degrees.
Old Jun 20, 2010 | 08:22 PM
rodj's Avatar
rodj
Does the O/d light on dash show up to show the computer is " trying " to operate the O/d ?
Have you checked fluid level in O/d ; low fluid will cause O/d not to operate
Or 176F in a '84
Old Jun 21, 2010 | 05:35 PM
gabezC4's Avatar
gabezC4
I always read people saying the OD won't work until you reach a certain temp. I just had my "switch" replaced last year when the car wouldn't engage into OD once I pushed the botton. Now when I drive her, the car could have a temp of LOW on the digital cluster and the OD comes on as soon as I press the button on my shifter. I wonder how if it has to be 140 or 170 degrees as I've read before?
Old Jun 21, 2010 | 08:17 PM
rodj's Avatar
rodj
Different O/d operating temps for different years
See
http://www.5speeds.com/43table.htm
Old Jun 21, 2010 | 08:38 PM
1stvet87's Avatar
1stvet87
if i am not mistaken the shifter mounted switch is an override which bypass's ECM comands but not 1st gear lockout switch.
Old Jun 24, 2010 | 02:58 PM
yellow88's Avatar
yellow88
4th Gear
Default Still having issues..
I have checked the fluid (it's full). The temp limit on mine is 122F. When I get to that temp I get the dash light which leads me to believe that the ECM is OK. The Shift button will turn the light on and off. I put a jumper from the O/D to 12v and it engaged... (good news). I looked for the relay on the firewall, but I don't know if I got the right one. I don't have two as one of the replies I got said I should. Any Ideas or suggestions would be great.. Thanks
To 4+3 Fun
