First time for brakes
Old Jun 27, 2010 | 10:18 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
jeez you guys like to complicate things
Checking those items and using only quality parts means you don't have to do the job again in a short time...
Old Oct 24, 2010 | 02:43 PM
xxanity1's Avatar
xxanity1
Cruising
Originally Posted by tyreguy25
Rather than using a C-Clamp, spend the ten dollars at O'Reilly and get a K-D tools pad spreader.
I want to recommend against this for a couple reasons.
Some pads on some cars have rivets that sit inside the piston well and you'll need to compress the piston before attempting to remove the pads. The spreader is useless in this case. (trust me, I've been there and done this) The pads designed like this don't allow for the caliper to be swung outward to drop pads and use the spreader.
The spreader only does the same job as a c-clamp if you don't have this problem with the rivets or raised metal, and the C-clamp can be used for other purposes where the spreader is only good for brake pads.
Old Oct 24, 2010 | 10:01 PM
drmrman's Avatar
drmrman
Shouldnt take you more then 10 mins a side... Other then the 5 lugs on each wheel its only 4 bolts on each side
Dont bleed the brakes. There is no need if the fluid was just flushed.
If you need a hand shoot me a PM!
Good luck!
Old Oct 24, 2010 | 10:05 PM
drmrman's Avatar
drmrman
Originally Posted by 1st87
try a rear hub bearing-now thats funnnnnnnnnnnnn!
Just did.... Those darn torx bolts are ANNOYING!!!!!!!
Old Oct 24, 2010 | 10:28 PM
samsonb's Avatar
samsonb
I changed the pads and rotors on my 89 a while back. Only thing I noticed was at the last second before I come to a complete stop, and as I take my foot off the brake. I get a brief sound/vibration and it sounds like the brakes groan. It will stay groaning if I'm inching forward. I never figured it out as it doesn't go away even with the brakes hot.
Old Oct 24, 2010 | 10:30 PM
samsonb's Avatar
samsonb
Originally Posted by Aurora40
Personally, I'd open the cap. Otherwise pressure builds in the master when you push fluid back in. It's easier to compress the pistons with the cap open.
It also makes it easier to keep an eye on the fluid level, as it may overflow when doing all the pads if it was ever topped off with worn pads.
I open the bleeder so trash exits the caliper instead of getting pushed up the brake system.
Old Oct 25, 2010 | 09:54 AM
seijack's Avatar
seijack
It is not a bad job at all. The fronts are the easiest. Take your time and do one side at a time. This way you can compare them to the other side if you run into problems. Have fun and make a winter project out of it....This is what I did...I am pretty **** so I removed the calibers and painted them....Looks great now!! just be sure that you get the e-clips installed correctly on the fronts..You do NOT want the pins backing out.
Rears before paint, I can't seem to find a pic of the fronts before
Fronts after paint, rotors also
Fronts with wheels installed.
It makes a world of difference on the car the brakes are seen but
not seen. I put on new wheels and I just had to paint the brakes and
rotors..remember 1 project almost always leads to ANOTHER!!!
Old Oct 25, 2010 | 10:11 AM
5POINT7's Avatar
5POINT7
4 month old thread revival...
Old Oct 25, 2010 | 11:07 AM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
But it saves me the search as I have to replace mine. I've done it many times but never on the vette so I was kinda wondering if I should do anything unusual or out of the ordinary.
some things are just meant to be!
One thing I always did was to open the bleeder valve to install the pads and then just rebleed the system. I always thought it best to always rebleed to make sure everything is set. I know it may be overkill but I have just always done it that way.
