Cooling Fan Problem
Old Jun 27, 2010 | 07:27 AM
Bobby Young's Avatar
Bobby Young
6th Gear
Default Cooling Fan Problem
Hello All, I'm new to the Forum and need help on a cooling fan problem. I purchased a 1990 coupe (31,500 miles) and found the temp gauge would climb into the shaded area while not moving. Neither the primary or secondary fans come on. So far I have checked and verified the following: 1. I checked all fuses and found no problem. 2. I jumped the A and B ports of the ALCL and both fans kick on. I believe this means both the fans and the relays are good. 3. If the AC is engaged the fans come on. Also found if the AC kicks out the fans also quit. 4. I did not find any flash codes other than 12 until I disconnected the coolant temp sensor in the intake which gave a code 15. 5. The cooling fan temp switch in the pass side head has a single wire Spade connector. Grounding this wire does not start the fans. All replacement temp switches I researched have a button type connector. I suspect this is the original switch. Perhaps the temp switch wire is open between the switch and the ecm?? Any suggestions?? Thanks Bob
Old Jun 27, 2010 | 08:16 AM
Hooked on Vettes's Avatar
Hooked on Vettes
Disconnect the electrical connector at the ECT (engine coolant Temperature sensor).
That's the plug with the Yellow and Black wire that you disconnected to get the error code 15.
With jumper clips or a piece of wire, short the Yellow wire to the Black wire. This should simulate the engine temp. is over 266 degress F. Start the engine. The ECM should turn the fans on.
If the fans work, that would indicate the ECT is bad. If you had a scan tool you could read what the ECM believes the engine temperature is.
The item you mentioned screwed into the passengerside head is the sender for the dash cluster temperature gauge.
Old Jun 27, 2010 | 09:07 AM
Bobby Young
6th Gear
Thank you for your recommendation. I jumped the yellow and black wire and the fans came on when I started the engine. I'll change out the ECT sensor and see how the temps are with the fans operating. What are your thoughts on the aftermarket low temp switch kit that kicks the fans on around 200 degrees?
Old Jun 27, 2010 | 09:51 AM
WW7's Avatar
WW7
I believe 200 degrees is a better place for the fan to come on then 228 degrees like it is now..Im sure there are people here that will disagree with me, but if you can keep your car under 200 degrees (like most other cars on the road) its better for parts longevity and the car as a whole..It sure can't hurt it to run cooler and in the long run will probably help...WW
Old Jun 27, 2010 | 09:56 AM
Hooked on Vettes
The car is new to you and is low mileage. Fix the problem and drive it.
The radiator and fan layout was redesigned for the 90 Model.
Usually the guys with the 85-89 engines complain about the
high engine temps.
1) Each fan has a relay. You can use a manual switch and ground the Light Blue/Black wire at each fan relay socket and manually control each fan. Kits are sold to do this or go to Radio Shack and purchase the parts.
2) You can purchase a fan switch that screws into the Drive Side head that will ground the fan relays to turn the fans on at a lower temperature. Problem is getting the pipe plug out of the head to install the new fan switch.
3) You can have your ECM calibration Eprom reprogrammed for lower fan turn on. Paying to have it done would be over $100.00.
Lay on your back in front of the vehicle and look for any accumulated road trash that blocks the radiator air flow.
Old Jun 27, 2010 | 11:07 AM
jeffp1167's Avatar
jeffp1167
I use a F-body thermal sensor to turn my fans on now instead of through the ecm. Mine does the same as yours pretty much the temp gauge shows around 240'ish before the fans come on, but my thermal sensor is for 228on-205off. Probably just your gauge is a bit off like mine, my gauge almost redlines before the fans come on but it never smells hot.
Old Jun 27, 2010 | 11:18 AM
Bronze85's Avatar
Bronze85
I would look into verifying the temp with a thermo gun or at least a thermometer to be sure it's not getting to 240 without any fan activity.
Old Jun 27, 2010 | 12:46 PM
blben4's Avatar
blben4
I put the after market switch on my '95 the fans come on at 200. was an easy fix and runs alot cooler now.
Old Jun 27, 2010 | 01:49 PM
SunCr's Avatar
SunCr
Just scan it so that you can see the Engine Coolant Temp Sensor. Non a/c specs for the '90 are 226 primary; 228 secondary. You've allready verified that the ECM can drive the Fans and that the Relays are good. What you want to know is if they're being grounded at spec temp. Doing anything else is a waste of time and money - you don't even know if it's broken.
Old Jun 27, 2010 | 02:49 PM
Bobby Young
6th Gear
I replaced the ECT sensor, started the engine and idled until temp gauge hit the caution shaded area prior to the 260 mark. Fans did not kick on. I heated the old sensor with a lighter and it had continunity. Engine cooled a little I removed the radiator cap. Inserted a thermometer and started the engine again. The temp gauge hit the shaded area prior to 260 but the thermometer read 200. I don't have a scan tool to see what the ecm temp is reading. I'm treading cautiously until I get grasp on the true temps. Thanks to all.
Old Jun 27, 2010 | 03:08 PM
MK 82's Avatar
MK 82
I haven't seen a problem to fix yet.. You need to speak in numbers instead of "in the shaded area."
Old Jun 27, 2010 | 03:51 PM
Bobby Young
6th Gear
My temp gauge redlines at 260 degrees. It has a "Warning" shaded area on the gauge just prior to the 260degree mark. When the engine is running the temp gauge will reach this warning area and the cooling fans have not come on. I replaced the ECT (Engine Coolant Temp) sensor and the fans still haven't come on. I have already verified the fans and relays are good. When I jumped the pigtail to the ECT the fans came on. What I need is to verify the true engine coolant temp which I do not have the equipment to do at this time. I am not sure of the temp gauge accuracy but I'm not willing to risk running the engine once the gauge has redlined. Perhaps you missed my earlier comments about the inop fans as the original problem.
Hooked on Vettes
Which indicates the dash gauge is not accurate.
The service manual does not give the resistance of the sensor when the temperature is above 210 F. You already determined when the resistance is zero the fans come on. So the only conclusion is the engine temperature is not hot enough for the ECM to enable the fans.
210 F = 185 ohms
160 F = 450 ohms
100 F =1.8k ohms
70 F = 3.4K ohms
40 F = 7.5K ohms
20 F =13.5K ohms
Old Jun 30, 2010 | 10:02 PM
Bobby Young
6th Gear
Final Update. I connected a secondary temp gauge along with the original gauge. I installed a thermometer where the radiator cap should be and idled the engine. The original temp gauge passed the 260 degree mark, the secondary temp gauge read about 200 and the thermometer hit 215 when the primary fan kicked in. Conclusion: The coolong system worked as it should. The factory temp gauge was no where near being accurate. Thanks to all for their input and ideas.
To Cooling Fan Problem
