C4 Frame braces
Old Jul 21, 2010 | 02:05 PM
  #41
-=Jeff=-'s Avatar
-=Jeff=-
Originally Posted by avigar
How would you calculate how much tightening of the rods is required? Trial and error I assume. Is there an initial setting that you would start from?
Correct Trial and Error..
yeah you start from tight..
Old Jul 21, 2010 | 05:23 PM
  #42
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
You know, I'd love to put one of those on corner weights and see how tightening and loosening it can transfer weight from one corner to another. Hmmmmmm....
Old Jul 21, 2010 | 11:15 PM
  #43
-=Jeff=-'s Avatar
-=Jeff=-
That would be cool to do..
Old Jul 22, 2010 | 03:38 PM
  #44
-=Jeff=-'s Avatar
-=Jeff=-
I talked to Jason today.. the deal has changed and been extended until after Carlisle.. everyone that has called and shown interest will get this deal as well
Introductory price of $550 SHIPPED!!!
I will get my website updated within the next couple of days
Old Aug 9, 2010 | 09:50 AM
  #45
romankrzy's Avatar
romankrzy
I'm thinking of taking advantage of this deal since I would like to drive the car with the targa off once in a while
I'm curious on the installation. Is there any pre tightening you should do before install? Should the targa be on and if yes then how tight?
Old Aug 9, 2010 | 11:31 AM
  #46
-=Jeff=-'s Avatar
-=Jeff=-
install them then adjust, it will take a bit of trial and error to get them right
Install them with targa on a bolted as you normally do. hood closed and hatch vent removed (if applicable) tighten them as you feel they need to be and try it out. at first my hood did not pop normally, after tightening a bit more the hood was fine.. Same with the targa, should still bolt on and off as before the braces were installed
Old Aug 9, 2010 | 12:29 PM
  #47
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I did my install with targa off and hood closed. Initially you spin the Heim joints to line them up so they will fit the brackets and then tighten them. I just reefed on them real hard with a huge crescent wrench that I inherited from my Dad. He had named the wrench "Proud Mary". I find no more need to adjust them any more. Hood, doors, rear hatch, targa all close and open as normal.
I will have my car at Carlisle (if I get my latest intake and fuel injector project finished in time) if anyone wants to see the installed kit. I will stop by Jason's booth and let him know where I can be found. Right now I am planning to park where Nutz4C4 parks down by the Callaway display.
Old Aug 9, 2010 | 03:28 PM
  #48
pantera1683's Avatar
pantera1683
You guys have had them on your cars for awhile now, do you still recommend them? What are your driving impressions like now that you've made all the tweaks?
Old Aug 9, 2010 | 03:57 PM
  #49
-=Jeff=-'s Avatar
-=Jeff=-
YES
The Car just feels tighter.. I don't regret having them at all
Old Aug 9, 2010 | 04:28 PM
  #50
pantera1683
I'm debating between getting the frame braces or taga truss. Jeff, did the frame braces significantly relieve the cowl shake with your top off?
Old Aug 9, 2010 | 04:53 PM
  #51
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Good question^
I'm guessing the answer is yes...
Old Aug 9, 2010 | 07:53 PM
  #52
-=Jeff=-'s Avatar
-=Jeff=-
Originally Posted by Tom400CFI
Good question^
Yes, the more I adjusted the better it got.. I still need a minor tweak to make it perfect..
Old Aug 10, 2010 | 07:23 AM
  #53
romankrzy's Avatar
romankrzy
...and a sign of "too tight" would be?
I'm guessing doors, hood, hatch not lining up but..........
Old Aug 10, 2010 | 07:45 AM
  #54
-=Jeff=-'s Avatar
-=Jeff=-
I honestly don't know about too tight as I have not gotten it that far yet
Old Aug 10, 2010 | 09:34 AM
  #55
corvetteronw
Cruise-In VIII
I must confess that I got these at a steep discount as mine were the first production model to be installed. I also submitted a story on the install to Corvette Enthusiast magazine so Jason gave me a break.
After driving the car with them on I would not want to be without them and would be more than willing to pay full price.
The only drawback I have noticed is that my 91 has a lopey idle and the precats must have loose junk inside of them as one of them rattles and makes it sound like a bad engine rod! Kind of embarassing:o
I ohmed my fuel injectors and found 1 real bad one and 2 that are off a bit. I also found some loose bolts when I removed the intake runners. I am in the process of replacing them now and I have also bought a catless front Y to install. Hopefully this will smooth out the idle and there won't be any more knock, knock, knock.
My theory is that the car's frame was loose enough to absorb the vibration in the past.
Old Aug 10, 2010 | 09:55 AM
  #56
shakedown067
That's a little closer to the kind of feedback it would take to drop that kind of cash. Too bad it's bad timing for me.
Old Aug 15, 2010 | 11:13 PM
  #57
Klondike's Avatar
Klondike
How do these effect where and how your car gets jacked for tire replacements on a shop lift, or where you jack & place stands when you do driveway work under the car?
To C4 Frame braces
Old Aug 15, 2010 | 11:45 PM
  #58
-=Jeff=-'s Avatar
-=Jeff=-
Been meaning to double check this.. have not had time yet
Old Aug 17, 2010 | 11:41 PM
  #59
RCD94's Avatar
RCD94
Price returns to $750 a kit at the end of August. That's a lot of money for that rig.
Old Aug 18, 2010 | 01:02 AM
  #60
pantera1683
$550 shipped isn't exactly cheap either.
