How much horsepower can...
Old Mar 22, 2002 | 11:43 PM
Idreamofvettes's Avatar
Idreamofvettes
Default How much horsepower can...
the stock drivetrain handle on a 92 vette handle? What is the weakest component?
Old Mar 23, 2002 | 01:57 AM
nsimmons's Avatar
nsimmons
Default Re: How much horsepower can... (Idreamofvettes)
auto or stick?
for an auto its gonna be the tranny first, then the read end/u joints
for a stick, the clutch then the ujoints, the tranny and dana 44 are pretty tough..
as long as you dont run slicks it should survive a fair bit over power, i would estimate over 400
Old Mar 23, 2002 | 06:59 AM
LPDesRoche's Avatar
LPDesRoche
Default Re: How much horsepower can... (nsimmons)
If its a stick it can hold loads of power. Your only limiting factor in that aspect is if you are going to run slicks or not? If not then 500hp is not a problem. I have seen more than that even without a problem.
Old Mar 23, 2002 | 08:32 AM
Nathan Plemons's Avatar
Nathan Plemons
I'm only making 336 hp, but I'm afraid to run slicks. I don't think I would break anything serious, just a few u-joints possibly, but I don't want the hassle. I am however not at all afraid of it on street tires, I'm looking to get up around 400 hp N/A with a set of heads and I still won't be worried about it.
Many years in the future when I put the supercharger on it as well I might start to get worried.
Old Mar 25, 2002 | 06:43 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
For what application. Drag racing, road racing, autocrossing, daily driver...whet tires...slicks, drag radials, street tires.
All depends. I have broken u-joints, half shalfs, hardened outer spindles, pistons, and I know others that have broken lifters, valve springs, rear ends on top of everything I have broken.
To How much horsepower can...
