AC question
Old Jul 6, 2010 | 07:10 PM
kelc317's Avatar
kelc317
Default AC question
I bought a can of r134a for my 87 but the hose that came with it won't fit on my ac unit.Does this mean i have a r-12 unit?I have a corvette book by Haynes and thats what it tells me i need.
Old Jul 6, 2010 | 07:30 PM
sailorsteve's Avatar
sailorsteve
Your car came with R12. If you want to switch to R134a you have to get the system evacuated. The two are not compatible.
Old Jul 6, 2010 | 09:31 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Its an easy change over. Can get everything you need at autozone. But you need to have your system completly vacuumed before adding diff. refig.
Old Jul 6, 2010 | 09:43 PM
kelc317's Avatar
kelc317
Has anybody tried Freeze 12?
Old Jul 7, 2010 | 12:11 PM
SunCr's Avatar
SunCr
80% R134 and it can't be mixed with R12 either. Mixing refrigerents is a good way to blow a hole in something as it can effectively double operating pressures. If you want to buy R12, get your license at www.epatest.com and buy all you want. Otherwise, whatever is in it needs to come out and replace the Accumulator so it doesn't fall apart and plug it up.
Old Jul 7, 2010 | 01:16 PM
mfi's Avatar
mfi
And r-12 has gotten cheaper now that most people don't want it anymore. I get for about 12 per can..bought a whole case at a car show last year.
Old Jul 7, 2010 | 01:42 PM
GTA8500's Avatar
GTA8500
"Accumulator so it doesn't fall apart and plug it up" so would i need to buy a new one?? plug what?? i was thinks about converting next week so this might help. if not ebay has alot R12 for sale
Old Jul 7, 2010 | 02:21 PM
sailorsteve
An advantage of R12 is that it cools better.
Old Jul 7, 2010 | 02:23 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
He's right. Especially in high heat/humidity environments like we're seeing right now in many part of the Southeast. My '92 blows ice box cold, so much so it numbs my hands on maximum output.
Old Jul 7, 2010 | 04:03 PM
Muffin's Avatar
Muffin
Thats because your 92 A/C system was designed to use R12. R134 will not be as efficient. A later built system, say my 2001 Ram truck, designed for R134 will freeze the ***** off a brass monkey. I, for one, think R134 sometimes gets a bad rap. FWIW I am using Freeze 12 in the 85 Vette. Works well but required the same flushing as R134.
Old Jul 7, 2010 | 06:00 PM
romankrzy's Avatar
romankrzy
I've put Freeze12 in my BMW 533i and My MB 380SL it works fine, there is a great guy on Ebay that sells it and has some really nice kits.
Old Jul 7, 2010 | 06:04 PM
romankrzy's Avatar
romankrzy
Are you sure you are not trying to put it on the high pressure side fitting? Is it a screw type fitting or a snap on type, the screw on type is an R12 system. The snap on type is the 134.
Old Jul 8, 2010 | 03:08 PM
SunCr's Avatar
SunCr
The fittings are different with R134 using a "quick connect" and R12 threaded. It's a safety feature. Mixing gases can lead to extraordinary pressures that will trip the High Pressure Limit; spurt gas from the compressor relief valve; and/or blow a hole in something - like the hood or yourself.
The Accumulator has 2 purposes - suck up any residual moisture using a desiccant that will otherwise create an acid and rot it out; and to boil off any liquid that didn't boil in the Evaporator which would otherwise hydrolock the compressor. It's innards, if original, are only compatible with R12. Dump something else in it and it falls apart. Those chunks are then sucked into the Compressor and before it seizes, spit out into the Condensor, lines, and everyting else plugging it up. If it keeps running long enough; see above about extraordinary pressures. You want cold air - not a car bomb, I think.
Old Aug 6, 2010 | 01:11 AM
SirNike80's Avatar
SirNike80
SunCr:
So if I were to put r134a into a r12 system, without changing any parts, it would be deterimental?
But just how deterimental?
Thanks in advance!!!
Old Aug 6, 2010 | 09:43 AM
RLG's Avatar
RLG
SunCr, said car bomb, that's pretty detrimental in my book.
bottom line is, I wouldn't do it.
Old Aug 6, 2010 | 09:52 AM
Goldcylon's Avatar
Goldcylon
The Freeze works well. 134a Sucks in the C4 even if YOU did the conversion properly.
Old Aug 6, 2010 | 12:30 PM
onedef92's Avatar
onedef92
Gold's right. I had R134a retrofitted for my car and went back to R-12 because I didn't like the vent temps (or lack thereof) R134a offered.
To AC question
Old Aug 6, 2010 | 12:31 PM
Sargevette's Avatar
Sargevette
Yup. Converted the 93 C4 over to it. Worked great and cheap to buy.
Old Aug 6, 2010 | 12:49 PM
onedef92's Avatar
onedef92
Freeze 12 is designed to mix with stock R-12 systems. R134a systems didn't come in production C4's until 1994. Was conversion necessary?
Old Aug 6, 2010 | 01:26 PM
SunCr's Avatar
SunCr
Freeze 12 doesn't mix with anything.
