Had my 95 jacked up yesturday and found a golf ball size hole in the driver's side floor board, it is right on the corner behind the the tire. What do you think caused it ?
I would think people not jacking it were it should be done. my 94 was like that. I epoxied the hole shut
Do you think it could of happened from when I had an Xpipe installed or from someone putting a jack in the wrong spot ? How and where did you apply the epoxie from the outside or inside?
I had one in the same location, not as large. Mine was about inch or so in diameter right on the corner that protrudes unprotected. Mine occurred as a result of an impact with road debris. Easy to fix in most cases. Cracked floors may be a different issue all together.
its hard to say when it happened you know what goes on with your car then any of us on here do. I just epoxied from the out side and smoothed it out. I also had a can of touch up spay paint the same body color and spayed it the match everything in
Thank you, where is New Oxford
Reason: spelling
